Force 32 bit install from dual arch dvd
    I have a amd 64 system and have installed the kubuntu 6.06.1 but I am having some repository issues and basically would like to run the 32 bit version anyway so i dont loose out on the 32 bit only packages as i like some of them. I am currently downloading the 32 bit version but I allready have the dual architecture dvd but cant figure out how to force the 32 bit install if possible at all... Not sure if it just autodetects and its not an option. Please help if you can.
    Thanks a lot
    adam bomber
