Change double mouse click in kicker?
    I can change to double clicking applications to run them, but it does not affect icons in the kicker bar, which still open "double" if double clicked, although the icons on the desktop and menu work correctly.
    Where can I change this setting?
    Regards<br />Matchless<br /><br />Proudly kubuntu!
    Re: Change double mouse click in kicker?
    I think it's the default action and you can't change it. they will open twice, if you double click them.
    cheers!
    -=|From the desk of|=-
    «•´¨*•.¸¸whoiam55.¸¸.•*¨`•»
    Reg. Linux User # 400637
      You can't, it is possible only if u configure the Application as Applet but consider that every applet will be loaded in memory.
      -------------<br />dentaku65<br />http://yep.it
        Thanks,
        I thought I was missing something, will just have to live with it untill someone finds the need to change this.
          I don't think someone going to do so, as this is not an error/bug. You should learn live with single click on taskbar
          cheers!
