How to use Oracle Java
    I would like to use Oracle java, as not all java software can use open jdk.
    The problem is how to run a jar file.
    I downloaded the latest java version from the oracle site, and unpacked it.
    Then I downloaded a jar file to try it, and made it executable, but it does not run.
    When I try to run it with openjdk, it says it needs oracle java.
    When I try to run it with oracle java, I get this
    I copied the jar file into the same directory as the java runtime and made it executable
    and then I try to run it from the terminal.
    marc@marc-samsung:/data/Downloads/jre1.8.0_241/bin$ ./java Mario.jar
    or
    marc@marc-samsung:/data/Downloads/jre1.8.0_241/bin$ ./java /data/Downloads/jre1.8.0_241/bin/Mario.jar
    Error: Could not find or load main class .data.Downloads.jre1.8.0_241.bin.Mario.jar
    I am an absolute beginner with java, so I may be overlooking something basic.
    Je suis Charlie, how many more people have to die for religions
    linux user #447706 on https://linuxcounter.net
    A good place to start:
    Topic: Top 20 Kubuntu FAQs & Answers
    Did you try:
    java -jar Mario.jar
    Did you check to see if your Oracle java executable is in your PATH? If not, did you add it to $PATH?
      Thanks for your help, the -jar option did the trick
