Panel autohide, can't quit Anydesk
    I've been using Kubuntu for a couple days. I'm running Anydesk. It puts an icon on the taskbar. I also right-clicked the panel, panel options, configure panel, more settings... and enabled autohide.
    Now, when I right click the Anydesk item, and reach to the "quit" option, the panel disappears before I can hit the quit text. This doesn't happen when I right-click other tasks, like the wifi or sound.
    Is there a way to make the panel stay up in such a case? (Would this be considered a bug?). I wish there were a way to press the shift key (or something) while the panel is raised, and hold it until I complete what I'm doing. There is literally no way to end Anydesk without reconfiguring the panel to not be auto-hidden.
    Thanks.
    After I suggested how nice it would be if I could hold the shift key, I hit a few keys and found that the "windows" key will hold up the panel until I hit the escape key. That works!
