I have a headless VirtualBox machine on one of my remote servers that has become unable to start. I'm not sure if this is due to any recent updates or if something got borked during a sudo apt-get autoremove. When I try to start up the VM I receive the following output:
I don't fully grasp recompiling a kernel module but I did try the vboxconfig command and got this:
The vbox-install.log is WAY beyond my comprehension but here's a link if anyone's interested:
As always, thanks in advance for any guidance or direction anyone can provide. You guys are the reason I come to this site before anywhere else
Moderator's note:
This was moved from the now-closed 16.04 Xenial forums
[gknbynw@QuickBox]:(0b)~$ VBoxManage startvm "MeGUI" --type headless
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (4.4.0-146-generic) or it failed to
load. Please recompile the kernel module and install it by
sudo /sbin/vboxconfig
You will not be able to start VMs until this problem is fixed.
Waiting for VM "MeGUI" to power on...
VBoxManage: error: The virtual machine 'MeGUI' has terminated unexpectedly during startup with exit code 1 (0x1)
VBoxManage: error: Details: code NS_ERROR_FAILURE (0x80004005), component MachineWrap, interface IMachine
[gknbynw@QuickBox]:(0b)~$ sudo /sbin/vboxconfig vboxdrv.sh: Stopping VirtualBox services. vboxdrv.sh: Building VirtualBox kernel modules. vboxdrv.sh: failed: Look at /var/log/vbox-install.log to find out what went wrong. There were problems setting up VirtualBox. To re-start the set-up process, run /sbin/vboxconfig as root. [gknbynw@QuickBox]:(0b)~$
https://drive.google.com/file/d/1mMBtXwt8k_C6ljKWEndYoZEbGo6ttlvo/view?usp=sharing
Moderator's note:
