I'm no expert. Just someone who uses, likes and values Kubuntu - no engineering skills or understanding (don't even know if this is in the right place - if not, sorry my bad)...
Anyway, system shows that there's an update/upgrade. Whether I select the taskbar icon and try to update that way (that just hangs with an open updating window and seems to do nothing - other than telling me I can't close it as it still has stuff to do).
If I try via the menu and open the Muon Package manager (and however I manage to get the package that's upgradeable to show up in the listing), I can tell it to do the update and it either hangs or does nothing.
The package is ppp (2.4.7-2+2ubuntu1.1) which shows as upgradable but then shows "no change" in the second column on the Muon window - I can meddle with showing it via status, I can meddle with it by getting it to list and a selected upgrade etc, then it doesn't matter what I do, it just won't upgrade the package - it just reverts the package listing as upgradeable and no change.
I "think" I may have got the system upgraded to 18.10 but I don't know as I did change the software sources to "normal" updates from LTS updates and I did install this as 18.04LTS
Can anyone suggest where I go from here please as I'm at a complete loss ?
