[SOLVED] Need help setting up multi-boot with btrfs
    [EDIT]
    The posts that lead directly to the solution in this thread are: [ 2, 4, 5, 22, 27 ]
    Synopsis:
    This clarifies oshunluvr's post on "
    More BTRFS fun: Multibooting to subvolumes on the same partition"
    It reconciles that post with booting from EFI ( original post is for MBR ) and shows how to configure grub for both distros.
    Note: my solution does not solve for problems arising from kernel updates. Oshunluvr's post on how to create a dedicated grub partition covers that. Mine is an intermediate solution which is easier in the short run but harder in the long run. Mine may help you understand grub a little better, which will make his more elegant solution easier to understand.
    [/EDIT]
    I've installed single boot distros many times. I tried to set up a dual-Linux boot system and what I ended up with is a 500gb drive with a 30gb Kali partition on sda4 without the ability to boot back into Kubuntu (that I could find). There are a lot of tutorials out there, most of which don't seem to really help.
    I'd like to set up my Thinkpad with at least two distros. My main would be Kubuntu 22.04 and then I want to have Kali as a second option.
    Some things I have noticed in the system as I have it now:
    • Partition manager (in Kali) shows Kubuntu has no mount point
    • Prior to installing Kali it was booting to grub from which I could run Kubuntu
    • After installing Kali /boot/grub/grub.cfg shows only Kali
    The parts I succeeded at:
    • created ESP on sda1
    • created swap on sda2 ( for hibernation )
    My criteria for success:
    • At least two distros
    • Each distro on a its own single partition
    • All partitions using btrfs
    • Each distro has its own home directory (not shared with other distros)
    • Each distro having a subvolume for @ and @home
    • Ability to boot to any installed distro from boot manager (grub or refind)
    What I need help with is the side by side installation of:
    • Kubunutu on sda3
    • Kali on sda4
    Partitions as currently set up:
    Click image for larger version  Name:	IMG_5821.jpg Views:	44 Size:	52.1 KB ID:	671910
    There are some good mulit-boot btrfs/grub resources here: https://www.kubuntuforums.net/forum/...trfs-subvolume
    I would suggest trying a sudo update-grub command to see if it can pick up the Kubuntu and add it to the menu for you
    Kubuntu 18.04 on AMD
      Assuming kali uses grub, and your system has booted into it.
      Firstly, does the /etc/default/grub have this line:
      GRUB_DISABLE_OS_PROBER=false
      If not, or it is commented out, edit it so that it does, then run sudo update-grub.
      The update-grub used to run the OS prober by default, but that was deemed to be a security risk, so now for it to run the weird double negative is needed.
      However, with btrfs, I'm not sure the os-prober works.
      So, another approach is creating the file /boot/grub/custom.cfg on kali with the contents:
      menuentry 'Kubuntu from custom'  {
          search --no-floppy --set=root --label kubuntu
          linux /@/boot/vmlinuz root=LABEL=kubuntu ro rootflags=subvol=@
          initrd /@/boot/initrd.img
      Grub these days checks for custom.cfg at boot time.
      Now,
      With btrfs this is not necessary; several distro installs can share one btrfs, and juggling free space by resizing partitions is obviated. A huge time saver. The different installs just have to use different subvolumes, with grub and /etc/fstab adjusted accordingly. IMO becoming up to speed with this approach is really good when problems occur; one can boot into snapshots to try things. At dist-upgrade time I usually have before and after bootable, and often keep an LTS going (that is, bootable and upgraded). Your install of kali suggests that you are the type of user that would benefit from this flexibility.
        I've read Oshunluvr's posts on maintaining grub and multi-booting from a single btrfs partition. I played with it a bit in my skunky-funky kubuntu/kali install and ended up not being able to boot into either. So I wiped them and now I have one big btrfs partition with Kubuntu 22.04, alongside the original ESP and swap.
        The short-short version of the steps to begin multi-boot from a single partition as I grasped them are:
        1. Boot with live and rename @ and @home
        2. Edit fstab to match new names
        3. Edit /boot/grub/grub.cfg
        4. Edit 40_custom
        5. boot into system and run `update-grub`
        With a 40_custom entry of:
        menuentry 'MENU_ENTRY' {
          insmod btrfs
          set root='(hd0,Kubuntu22)'
          configfile /boot/grub/grub.cfg
        One thing I found was that I could not edit grub.cfg from a live-usb. Which leads me to think I should edit the file that explicitly states that I should not edit it as step 1 with live-booting being step 2.
        How am I doing?
          os_prober didn't work in the past with btrfs partitions other than the host partition because of the use of subvolumes prevented finding the kernel and initramfs files. This was identified as a bug quite awhile ago but I don't know if it was ever fixed.
          In my view you have a few choices:
          1. Leaving things as they are and:
          Add Kubuntu to /etc/grub.d/40_custom like this:
          menuentry 'Kubuntu 22.04' --class kubuntu {
             insmod part_gpt
             insmod btrfs
             search --no-floppy --fs-uuid --set=root <UUID FROM SDA3 HERE>
             configfile /@/boot/grub/grub.cfg
          Obviously change the above if needed. For example, "@" is the default root subvolume so if you changed it in the Kubuntu install, you would need to change it here also. Also "insmod part_gpt" would need to be "insmode_mbr" if you're not using GPT (you should be IMO). Then make 40_custom executable and run update-grub. This should be maintenance free going forward as any time you do a kernel update to Kubuntu, it will update it's own grub.cfg. It won.t matter if Kali updated gr or not. This is also the easiest option to set up.
          Other options include:
          2. Moving the Kali subvolumes to SDA3 and booting from a single btrfs file system. This may require renaming subvolume(s).
          3. Creating a third install to just handle booting.
          The disadvantage to dual booting on a single disk is Kali currently "owns" grub. Thus if Kali becomes unbootable or you remove it, your entire system is not bootable. You could re-install grub from Kubuntu and flip the setyp but you're still in the same predicament of have a "one fail means all are failed" situation. This is why I use the third option.
          Both the 2nd and 3rd options are more work to set up, but have advantages like taking advantage of the shared partition space made possible by the use of btrfs subvolumes.
          The 3rd option is the most unlikely to leave you with an unbootable computer and adds the advantage of one more bootable OS to "fix" one of the others if need be. I use Ubuntu Server as my "grub" OS with no desktop at all, just console access. I set up it's grub menu to default to my primary OS with a 3 second menu window to change to another if I want to. Once it's set up, I need only update grub on the boot OS when I add or delete an install. I also have set up the ability to boot directly to many different ISOs. This makes it super easy to install a new distro or just try one out in a live session on bare metal.
            In e.g. openSUSE and Garuda it currently does work, in *Ubuntu and Debian it does not.
            As Debian- and *Ubuntu-based systems are two of my three primary systems I use a custom.cfg in /boot/grub to be able to boot from systems that I installed on btfrs partitions.
              How does one determine which install "owns" grub?
              How can that ownership be changed?
                Each os has its own bootloader, so you'll have multiple grubs. You choose which one to use as the "main" one based on your boot device selection in your bios.
                One thing to keep in mind that grub is usually only updated during kernel updates, but grub changed it's default actions for this and doesn't probe for new OS installs automatically any more, in most distros. You may want to enable this in your main grub so that it sees both new OS installs as well as existing installs with new kernels, if you have any issues booting other grub selections in your selected boot device.
                You can always always use your system's hotkey for boot options to select the desired OS to load.
                  sudo efibootmgr -uv
                  may reveal which distro installed grub. Generally, the last distro you installed will have installed it's version of grub on SDA. Based on the info you provided above I assume Kali is the grub "owner". One clear indicator is whatever distro is first in the boot menu is the distro that installed grub last.
                  To change the "owner", boot into that distro and run "sudo grub-install"
                  I'm not an EFI expert, so Claydoh's info over rides mine in this regard.
                    Not an expert, but I grok it enough to get myself in trouble 😵‍💫
                    Each separate distro will have it's own separate Grub, with separate bootloader files in the EFI partition. Your boot order preference in the bios determines which bootloader you get.
                    The confusing part is that each grub is capable of booting all the other OS installs (if each has the OS prober option enabled). It doesn't help that grub decided to disable os-prober for valid security reasons, but they never have developed a proper way to fix or replace this, I guess
                    efibootmgr can change the boot order in the bios so you don't need to reboot to change this.
                    Windows updates have been known to change the boot order using whatever its equivalent to efibootmgr is.
                      Oh, I can confuse even more…
                      Problems can occur when you use two or more distributions that are based on the same "parent" distro, like e.g. Kubuntu 22.04 and Kubuntu 23.04 are both based on Ubuntu, and you use the same EFI partition for them.
                      In this scenario GRUB (- in most cases unless the distribution has explicitely changed that) will install files of the same name in the "ubuntu" directory in your EFI partition and overwrite the files from the other Ubuntu-based system when writing to /boot/efi.
                      (This is one of the reasons why I have a seperate EFI partition on each of my three internal drives.)
                      TwoFistedJustice - don't let this post confuse you, sorry - it is not important for you:
                      -> This should not be the case for the OP, though, as Kali Linux is based on Debian and Kubuntu is based on Ubuntu and therefore there will be both a "debian" (or even "kali"?) and an "ubuntu" directory in a single EFI partition.
                      Last edited by Schwarzer Kater; Jul 03, 2023, 02:48 PM. Reason: added a non-confusion arrow
                        Problems can occur when you use two or more distributions that are based on the same "parent" distro, like e.g. Kubuntu 22.04 and Kubuntu 23.04 are both based on Ubuntu, and you use the same EFI partition for them.​
                        I purposely skipped that one for the moment, to lessen the amount of confusing confusions in one post.
                        That and my break was ending.
                          We try not to: Confuse the confused with confusing confusions.
                            It's normally the last to be installed (some installers let you turn off the installation of a boot loader; to do that with ubiquity one can run it with the -b switch.)
                            The last install to run update-grub takes ownership of the boot. update-grub may be run during normal updates, particularly if there's a new linux kernel. It's somewhat unpredictable, and hidden from the user if Discover is used for the updates.
                            The other posters have suggested using efibootmgr, and I think that's a good suggestion, but it won't tell between various grub installations of Ubuntu variants. For some versions of grub, and without secure boot, the file that counts is /boot/efi/EFI/ubuntu/grub.cfg. I think it's always there, and says where the boot goes, but with secure boot editing it may not work, the location of where the boot goes might be baked into a signed image.
                            IMO with multiple installs this a failed boot waiting to happen; "braindamage" (an old Unix term).
                            A solution is to designate which grub install should be the controller and uninstall grub and any other boot loaders in the others. A more flexible approach is to only uninstall the package grub-efi-amd64. Note just that package; the "details" for it says "Installing this package indicates that this version of GRUB should be the active boot loader."
                            sudo apt install grub-efi-amd64-bin
                            sudo apt remove grub-efi-amd64
                            ​The first is just to mark the package as "manually installed", so that the subsequent removal doesn't take it out.
                            Another approach is to make a stand-alone grub, independent of any particular distro and install. That's what I do on my desktop and IMO it's far, far less time and effort that way. All that update-grub machinery caused trouble and failed boots so often. One takes on updating it, but there's a couple of simplifications possible that makes the need for updating infrequent; I've gone years without having to make a change.
                              After renaming my subvolumes @ and @home to @kubuntu and @home_kubuntu, when editing grub.cfg should I be doing something like this?
                              Take an entry such as:
                              171 │menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-73ffa900-dca2-47f2-9e0b-f8c1942ef918' {
                              172 │ recordfail
                              173 │ load_video
                              174 │ gfxmode $linux_gfx_mode
                              175 │ insmod gzio
                              176 │ if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
                              177 │ insmod part_gpt
                              178 │ insmod btrfs
                              179 │ set root='hd0,gpt2'
                              180 │ if [ x$feature_platform_search_hint = xy ]; then
                              181 │ search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt2 --hint-efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2 [MY-UUID]
                              182 │ else
                              183 │ search --no-floppy --fs-uuid --set=root [MY-UUID]
                              184 │ fi
                              185 │ linux /@/boot/vmlinuz-5.19.0-46-generic root=UUID=[MY-UUID] ro rootflags=subvol=@ quiet splash $vt_handoff
                              186 │ initrd /@/boot/initrd.img-5.19.0-46-generic
                              187 │ }
                              and change the last two lines to this:
                              185 │ linux /@kubuntu/boot/vmlinuz-5.19.0-46-generic root=UUID=[MY-UUID] ro rootflags=subvol=@kubuntu quiet splash $vt_handoff
                              186 │ initrd /@kubuntu/boot/initrd.img-5.19.0-46-generic
