Best performance tweaks?
    For the following system what performance tweaks would people recommend?
    it's fast already, but always trying to wring more out of it
    MSI 990FXA motherboard
    amd FX-8370 8-core cpu
    32 Gb ram
    500 Gb Patriot Blast SSD
    2x3Tb hdd
    1x4Tb hdd
    bluray read/writer
    Packaged in a nice zalman case with self-regulating fans
    Azio backlit keyboard
    Corsair gaming mouse
    All mated to a 50inch HDTV
    Internet speed is roughly 225 Mbps
    My own tweaks? Not sure I'd recommend for everyone but I disable baloo (file indexer) and since I use no KDE PIM applications akonadi (contacts database) is also disabled.
    My 64-bit installation with conky, yakuake and a little bit of eye candy uses about 425MB of RAM at idle.
    But - unused resources are wasted resources. I wouldn't worry so much as the RAM you save is just gonna be turned into disk buffers anyway; I'm into saving processor cycles, not memory. As with any other computer disable what you don't use and think hard about what runs at startup - and if you really need to run it at startup uptime says it takes about three seconds more to start KDE than it does to start openbox on my machine - and for me that's a more than acceptable price to pay.
    Hope this helps -
    -- anais nin
      Move /tmp to tmpfs.
      Reduce swappiness.
      Reduce vfs_cache_pressure to 50 (debatable).
      Set all file systems to noatime or at least relatime.
      Disable unneeded TTYs.
      Network changes:
      Disable ipv6 if you're not using it.
      Tune ipv4 for performance.
      Here's some others: https://easyengine.io/tutorials/linux/sysctl-conf/
        Move /tmp to tmpfs.
        Reduce swappiness.
        Network changes:
        /etc/securetty shows 63 TTYs and a whole host of others tied to various serial cards. Should I just disable TTYs 3-63? I'll only ever use one or two
          Hope this helps -
          Mine is sitting at 10.3Gb but I have 8G in a ramdrive, playing music on firefox and running win7 in virtualbox with 8Gb ram
            If your RAM usage exceeds installed RAM that thing's gotta be swapping to disk like crazy.
            A ramdrive isn't gonna help you much if the rest of the system is swapping to disk; the trick here is to not use more resources than you have available. No amount of tweaking is gonna help much if you're using a couple GB more RAM than you have installed
            -- anais nin
              Actually, I realize that with systemd TTYs are handled differently. They're started on demand now, so you can disregard that suggestion.
                32 Gb ram
                2x3Tb hdd
                1x4Tb hdd
                I doubt the ram drive is slowing down the system
                  Seriously, the areas to look at are the bottlenecks: network speed tuning and file system performance are likely going to be the places you'll see the largest improvements. Video driver tuning might do a bit also, but mostly you're constrained by hardware when it comes to CPU and Video performance.
                    You could also install phoronix-test-suite and then compare your results at openbenchmarking.org and Phoronix.com.
                      Oops. Apparently reading comprehension is not my strong suit today
                      Last edited by wizard10000; May 01, 2017, 12:22 PM. Reason: used different words :)
                      -- anais nin
                        Unless this was mentiond before there is value in disabling systemd services which are not needed. I disable bluetooth, avahi, modem.
                        This is an awesome tutorial
                        https://www.linux.com/learn/cleaning...tartup-process
                          I would also look at disabling systemd services that are not needed. For example I disable bluetooth, Avahi and modem services
