I am having a hard time installing the gmail feed widget, and I'm not sure how to proceed. I am a Linux novice, so I'm not sure what information would be helpful. This is what the output in terminal was when I tried to run cmake to install the feed.
What should I do, and what information do others need to help me figure out what went wrong?
Thank you so much for your time!
comptroller@comptroller-desktop:~/Downloads/gmailfeed-master$ cmake .
-- The C compiler identification is GNU 5.4.0
-- The CXX compiler identification is GNU 5.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Warning at /usr/share/ECM/modules/ECMQueryQmake.cmake:22 (message):
Failed call: qmake-qt5 -query "QT_INSTALL_PREFIX"
Call Stack (most recent call first):
/usr/share/ECM/kde-modules/KDEInstallDirs.cmake:431 (query_qmake)
CMakeLists.txt:11 (include)
CMake Error at /usr/share/ECM/modules/ECMQueryQmake.cmake:23 (message):
QMake call failed: No such file or directory
-- Configuring incomplete, errors occurred!
See also "/home/comptroller/Downloads/gmailfeed-master/CMakeFiles/CMakeOutput.log".
