Sound Problem
    Sound Problem
    Hi, I'm pretty new to Kubuntu, just switched about 3 weeks ago. The problem I am having is that everytime I reboot my computer, sound won't work. Any ideas how to fix this?
    Re: Sound Problem
    Try to follow ALL the suggestions in this HowTo. At the very least, you'll a lot of useful things about debugging hardware, and you stand a very good chance of getting your sound back.
      Re: Sound Problem
      My brother fixed it for me once, it was just that everything auto-updated except my kernel headers or something.
      My output of trying to restart alsa is this
      tree@sour:~$ /etc/init.d/alsasound restart
      Shutting down sound driver: !!!alsactl not found!!! ERROR: Removing 'snd_opl3_lib': Operation not permitted
      ERROR: Module snd_timer is in use by snd_opl3_lib
      ERROR: Module snd_hwdep is in use by snd_opl3_lib
      ERROR: Removing 'snd_mpu401_uart': Operation not permitted
      ERROR: Module snd_rawmidi is in use by snd_mpu401_uart
      ERROR: Module snd_seq_device is in use by snd_opl3_lib,snd_rawmidi
      ERROR: Module snd is in use by snd_opl3_lib,snd_timer,snd_hwdep,snd_mpu401_uart,s nd_rawmidi,snd_seq_device
      done
      ALSA driver is already running.
      And if I try running kmix i get this
      tree@sour:~$ kmix
      X Error: BadDevice, invalid or uninitialized input device 168
      Major opcode: 145
      Minor opcode: 3
      Resource id: 0x0
      Failed to open device
      Major opcode: 145
      Minor opcode: 3
      Resource id: 0x0
        Re: Sound Problem
        The kmix errors have nothing to do with your present problem. You will see those every time you try to start a GUI program, like kmix, from the command line. To find out how to get rid of them, search the forum for the "wacom". Start kmix from the multimedia section of the K menu.
        Try switching temporarily to a different sound driver in the "System Settings" > "Sound & Multimedia" > Hardware Tab > "select audio device" dropdown box.
          Re: Sound Problem
          hmm i can't find any sound devices in /dev
            Re: Sound Problem
            They're called audio. Look for the word audio in the group column when you have konqueror in "detailed list view" or to find them all in swell foop, start a konsole and rune the command
            ls-l /dev | grep audio
            That's ell-es dash ell "pipe" grep audio.
            There's also a whole directory called /dev/snd/.
