Can't seem to get a bootable USB using unetbootin, live usbcreator, or any other tool I've tried. Reduced to writing dvds. Not hard, but uses my stash. Anyone know of a good program? Ideally, I'd like to put a few live cd/dvds on a 32Gb stick.
Bootable USB
Originally posted by vsreeser View PostCan't seem to get a bootable USB using unetbootin, live usbcreator, or any other tool I've tried. Reduced to writing dvds. Not hard, but uses my stash. Anyone know of a good program? Ideally, I'd like to put a few live cd/dvds on a 32Gb stick.
And neither unetbootin nor dd does multiple ISOs on a single thumb drive, alas.
Use dd.
It works from 11.10 and after because Ubuntu switched to hybrid disk images.
https://www.kubuntuforums.net/showth...l=1#post378712
Beware UNetbootin, issues have been reported,
Use Edit > Find -- UNetbootin on this page to see the issues:
https://help.ubuntu.com/community/In...n/FromUSBStick
People posting many issues, failures with it. It failed me the other day creating Boot Repair USB.An intellectual says a simple thing in a hard way. An artist says a hard thing in a simple way. Charles Bukowski
Some reports that UNetbootin not working on Debian UEFI systems.
dd:
As usual, make sure the boot mode is "matched up."
E.g., suppose your computer boots by UEFI mode.
Then choose 64-bit versions of the programs you dd to a flash drive (or, otherwise, program version indicated for "newer" systems), and then boot that flash drive in UEFI mode (by entering your firmware setup and selecting to boot the UEFI version of that flash drive).An intellectual says a simple thing in a hard way. An artist says a hard thing in a simple way. Charles Bukowski
Originally posted by Qqmike View PostSome reports that UNetbootin not working on Debian UEFI systems.
dd:
Found a Win8 box on a pile of rubble at an abandon house?
Seems like an example of the cost of ignorance: equating Windows with a PC and thinking that since Win8 is worthless the PC must be as well, since they are "one and the same". Penguins know better."A nation that is afraid to let its people judge the truth and falsehood in an open market is a nation that is afraid of its people.”
Originally posted by GreyGeek View PostFound a Win8 box on a pile of rubble at an abandon house?
I just put grub on a stick and then manually built a grub.cfg that would boot ISOs. Then I just copy the ISO to the stick and edit grub.cfg. Not all ISOs can boot this way but a lot can...
https://wiki.archlinux.org/index.php...boot_USB_drive
oshunluvr: I just put grub on a stick and then manually built a grub.cfg that would boot ISOs.An intellectual says a simple thing in a hard way. An artist says a hard thing in a simple way. Charles Bukowski
