LibreOffice Calc -- more help needed!
    [SOLVED] LibreOffice Calc -- more help needed!
    I know how to 'freeze' things to make a row/rows stationary at the top of the spreadsheet, so you can scroll the spreadsheet up and down without losing sight of the 'frozen' row(s). But is there a way to freeze it SIDEWAYS? I want to be able to scroll left/right without losing sight of several COLUMNS on the left.
    Thanks!
    It looks similar for both types
    https://help.libreoffice.org/Calc/Fr...mns_as_Headers
    Select the column to the right of where you want it frozen. No clue as to how this would affect a complex sheet, though.
      What claydoh said. The trick can be, turn off the existing freeze first.
        Thanks! I should've searched for the info myself, but I'm glad you did it for me.
        This was the missing link:
        "To freeze both horizontally and vertically, select the cell that is below the row and to the right of the column that you want to freeze."
