remember virtual cd?
    I have 3 disk images I made with virtual cd a few years ago. Nothing wants to open them. When I try to search the net, i get instructions on how to play vcds. These are images of Ageof Mythology and the titans expansion. Old game, but I still enjoy playing it, so want to install in play on linux if I can convert or extract the images
    are these .ISO images or what ?
      They are. Made originally with the program virtualcd
      http://download.cnet.com/Virtual-CD/...-10383683.html
      I used magicdisk to load them in windows. Can't find a version of magidisk or magiciso to use in linux.
      Tried using isobuster through wine. That didn't work. First thing I tried was mounting wiht dolphin. It fails too. Thought about downloading new iso's but couldn't find any torrents that work. Can't my find my disks either or I would just make new iso
        Try right-clicking on the file, and select Open With >> Ark, if all you want is to extract files. I thought that the k3b burner program also opened iso files as well as burned them, but I can't seem to see where.
        For mounting, there are also right-click context menu addons for Dolphin that are simple to use in Dolphin: >> control >> configure Dolphin >> Services >> Dowload NEw Services >> search for "iso", there should be few.
        Mounting iso images is also an easy way to get one's feet wet with the terminal:
        https://help.ubuntu.com/community/MountIso
        And there are a number of gui programs that are available in the Muon Discover/software center/Package Manager
        Many like the dolphin addon as it is the quickest and easiest to use, followed by the command line as it is fairly simple command to run.
          Tried all these things before. Also tried renaming to .iso fle. All failed to open. Will keep looking. And look for my own cds which are somewhere in this house
            Then they are not actually iso images, but some other format.I should have asked what file type the images are.
              They were made with H&H virtualcd. Not sure the program even exists anymore. Finding my cds has proven a problem. If you have teenagers at home, you'll know why I can't find anything
                once agin ,,,,are they .iso ,,,,if yes then just try to mount it from the CLI
                sudo mkdir /mnt/iso
                sudo mount -v -t iso9660 /path/to/.iso /mnt/iso
                then you can go to /mnt/iso and see the files or maby get some info ,,,like wrong file system type or something
                  Doing a simple search using DuckDuckGo I found this web site -> http://www.virtualcd-online.com/
                  The software is only for Windows but you may be able to run it through Wine or through Windows in a VM (if you have it).
                    If we knew the file type created (what file extension) we might be able to find what to open it/how to open it with. I don't have windows handy, and don't feel like installing and setting up wine.
                      Have a winxp and win 7 set up. Will try there. If magicdisc would run on linux, I could open it with that too
                        you can try
                        acetoneiso or furiousisomount
                        one of them may mount that format.
                        although FCD is not an image format i have seen before...
                        (top of thread: thread tools)
