Dragon Player not playing on Vivid
    [SOLVED] Dragon Player not playing on Vivid
    Update:
    Solved by installing gstreamer1.0-libav as caught by Wheel Inventor below.
    Why I didn't have that lib shall remain a mystery.
    Just curious if Dragon Player is not playing anything for others.
    It starts fine, it shows the name of the video in the bottom of the window, but no video or sound.
    Starting it in a konsole shows no errors (other than some probably innocuous ones about QPainter and mime types not related to mp4).
    No errors in syslog.
    Reinstall didn't help.
    Moving .kde/share/config/dragonplayerrc didn't help.
    Installed Kaffeine and it works.
    At here...
    Working at here...
    The Dragon is using the the KDE 4 - > Phonon -> Gstreamer/VLC backend
    :~$ apt-cache show dragonplayer
    Depends: kde-runtime, libc6 (>= 2.14), libkdecore5 (>= 4:4.4.0), libkdeui5 (>= 4:4.9.98), libkio5 (>=4:4.3.4), libkparts4 (>= 4:4.5.85), libphonon4 (>= 4:4.6.0really4.5.0), libqt4-dbus (>= 4:4.5.3), libqtcore4 (>= 4:4.8.0), libqtgui4 (>= 4:4.5.3), libsolid4 (>= 4:4.5.85), libstdc++6 (>= 4.1.1), phonon
    What backend are you using ?
    Packages: http://packages.ubuntu.com/search?ke...id&section=all
    At here Gstreamer.
    The Kaffeine is using the KDE 4 with the Xine: https://www.kubuntuforums.net/showth...l=1#post359942
      System Settings > Multimedia shows "Phonon Gstreamer", version 4.8.2.
      I haven't (knowingly) changed that or anything multimedia related. It has worked since the initial install. I don't use it that often, so not sure when it stopped working.
      ~ $ aptitude search ~igstreamer
      i   gstreamer-qapt                                         - GStreamer plugin to install codecs using QApt
      i   gstreamer0.10-nice                                     - ICE library (GStreamer 0.10 plugin)
      i   gstreamer0.10-plugins-base                             - GStreamer plugins from the "base" set
      i   gstreamer0.10-plugins-good                             - GStreamer plugins from the "good" set
      i   gstreamer0.10-pulseaudio                               - GStreamer plugin for PulseAudio
      i   gstreamer0.10-x                                        - GStreamer plugins for X11 and Pango
      i   gstreamer1.0-nice                                      - ICE library (GStreamer plugin)
      i   gstreamer1.0-plugins-base                              - GStreamer plugins from the "base" set
      i   gstreamer1.0-plugins-good                              - GStreamer plugins from the "good" set
      i   gstreamer1.0-plugins-ugly                              - GStreamer plugins from the "ugly" set
      i   gstreamer1.0-plugins-ugly-amr                          - GStreamer plugins from the "ugly" set
      i   gstreamer1.0-pulseaudio                                - GStreamer plugin for PulseAudio
      i   gstreamer1.0-x                                         - GStreamer plugins for X11 and Pango
      i   libgstreamer-plugins-base0.10-0                        - GStreamer libraries from the "base" set
      i   libgstreamer-plugins-base1.0-0                         - GStreamer libraries from the "base" set
      i   libgstreamer-plugins-good1.0-0                         - GStreamer development files for libraries from the "good" set
      i   libgstreamer0.10-0                                     - Core GStreamer libraries and elements
      i   libgstreamer1.0-0                                      - Core GStreamer libraries and elements
      i   libreoffice-avmedia-backend-gstreamer                  - GStreamer backend for LibreOffice
      i   phonon-backend-gstreamer                               - Phonon GStreamer 1.0 backend
      i   phonon-backend-gstreamer-common                        - Phonon GStreamer 1.0.x backend icons
      i   phonon4qt5-backend-gstreamer                           - Phonon Qt5 GStreamer 1.0 backend
      Confirmed that both phonon-backend-gstreamer and phonon4qt5-backend-gstreamer are 4.8.2.
      ~ $ apt-cache policy dragonplayer
      dragonplayer:
        Installed: 4:14.12.0-0ubuntu1~ubuntu15.04~ppa2
        Candidate: 4:14.12.0-0ubuntu1~ubuntu15.04~ppa2
        Version table:
       *** 4:14.12.0-0ubuntu1~ubuntu15.04~ppa2 0
              500 http://us.archive.ubuntu.com/ubuntu/ vivid/universe amd64 Packages
              100 /var/lib/dpkg/status
        At here...
        'gstreamer' -at here:
        i   gstreamer-qapt                             - GStreamer plugin to install codecs using QApt       i A gstreamer0.10-nice                         - ICE library (GStreamer 0.10 plugin)
        i A gstreamer0.10-plugins-base                 - GStreamer plugins from the "base" set
        i A gstreamer0.10-plugins-good                 - GStreamer plugins from the "good" set
        i A gstreamer0.10-pulseaudio                   - GStreamer plugin for PulseAudio
        i A gstreamer0.10-x                            - GStreamer plugins for X11 and Pango
        i A gstreamer1.0-libav                         - libav plugin for GStreamer
        i A gstreamer1.0-nice                          - ICE library (GStreamer plugin)
        i A gstreamer1.0-plugins-base                  - GStreamer plugins from the "base" set
        i A gstreamer1.0-plugins-good                  - GStreamer plugins from the "good" set
        i A gstreamer1.0-plugins-ugly                  - GStreamer plugins from the "ugly" set
        i A gstreamer1.0-plugins-ugly-amr              - GStreamer plugins from the "ugly" set
        i A gstreamer1.0-pulseaudio                    - GStreamer plugin for PulseAudio
        i A gstreamer1.0-x                             - GStreamer plugins for X11 and Pango
        i A libgstreamer-plugins-base0.10-0            - GStreamer libraries from the "base" set
        i A libgstreamer-plugins-base1.0-0             - GStreamer libraries from the "base" set
        i A libgstreamer-plugins-good1.0-0             - GStreamer development files for libraries from the "
        i A libgstreamer0.10-0                         - Core GStreamer libraries and elements
        i A libgstreamer1.0-0                          - Core GStreamer libraries and elements
        i A libqtgstreamer-1.0-0                       - C++ bindings library for GStreamer with a Qt-style A
        i A libqtgstreamerui-1.0-0                     - QtGStreamerUi library
        i A libreoffice-avmedia-backend-gstreamer      - GStreamer backend for LibreOffice
        i A phonon-backend-gstreamer                   - Phonon GStreamer 1.0 backend
        i A phonon-backend-gstreamer-common            - Phonon GStreamer 1.0.x backend icons
        i A qtgstreamer-declarative                    - QML plugins from QtGStreamer
        You don't have the 'gstreamer1.0-libav'
        Description: libav plugin for GStreamer
        This GStreamer plugin supports a large number of audio and video compression
        formats through the use of the libav library. The plugin contains GStreamer
        elements for encoding 40+ formats (MPEG, DivX, MPEG4, AC3, DV, ...), decoding
        elements for decoding 90+ formats (AVI, MPEG, OGG, Matroska, ASF, ...),
        demuxing 30+ formats and colorspace conversion.
        http://www.libav.org/
        http://gstreamer.freedesktop.org/
          Step 1.
          $ sudo aptitude install gstreamer1.0-libav
          Step 2. Try playing something with Dragon.
          Step 3. Great Success!
          Step 4. Post results and a thank you to Wheel Inventor.
            nice thread!
            woodsmoke
