I'm planning to do a server install (minimal install from the Alternate Install CD), and then just install kde-core, instead of kubuntu-desktop.
My question would be what do I lose by not installing kubuntu-desktop? I know that I will not be getting the kubuntu default settings, for one. But are there other side effects that I might encounter? Will I have problems upgrading packages? Or will I have dependency problems?
A side/related question would be, if I did a server (minimal) install and then installed kubuntu-desktop, would I end up with a smaller, lighter system or will it be exactly, as in exactly the same if I did a normal Kubuntu install?
Thanks!
Thanks!
