I've been trying to run sqlninja and been having some problems with the installation of the perl modules to run it. Any ideas what could be causing this would be appreciated greatly.
output:
It would appear there is a problem with gcc. Not sure what though.
Ican post a copy of config.log is need be. Thanks in advance.
output:
root@root-desktop:/home/karl/Desktop/sqlninja-0.1.0alpha# [b]perl -MCPAN -e 'install Net::DNS::Nameserver'[/b] CPAN: Storable loaded ok Going to read /root/.cpan/Metadata Database was generated on Fri, 11 Aug 2006 01:34:36 GMT Running install for module Net::DNS::Nameserver Running make for O/OL/OLAF/Net-DNS-0.58.tar.gz CPAN: Digest::MD5 loaded ok Checksum for /root/.cpan/sources/authors/id/O/OL/OLAF/Net-DNS-0.58.tar.gz ok Scanning cache /root/.cpan/build for sizes Net-DNS-0.58/ Net-DNS-0.58/Changes Net-DNS-0.58/contrib/ Net-DNS-0.58/contrib/check_soa Net-DNS-0.58/contrib/check_zone Net-DNS-0.58/contrib/dnswalk.README Net-DNS-0.58/contrib/loc2earth.fcgi Net-DNS-0.58/contrib/loclist.pl Net-DNS-0.58/contrib/README Net-DNS-0.58/demo/ Net-DNS-0.58/demo/axfr Net-DNS-0.58/demo/check_soa Net-DNS-0.58/demo/check_zone Net-DNS-0.58/demo/example_recurse.pl Net-DNS-0.58/demo/mresolv Net-DNS-0.58/demo/mx Net-DNS-0.58/demo/perldig Net-DNS-0.58/demo/README Net-DNS-0.58/demo/trace_dns.pl Net-DNS-0.58/DNS.xs Net-DNS-0.58/lib/ Net-DNS-0.58/lib/Net/ Net-DNS-0.58/lib/Net/DNS/ Net-DNS-0.58/lib/Net/DNS/FAQ.pod Net-DNS-0.58/lib/Net/DNS/Header.pm Net-DNS-0.58/lib/Net/DNS/Nameserver.pm Net-DNS-0.58/lib/Net/DNS/Packet.pm Net-DNS-0.58/lib/Net/DNS/Question.pm Net-DNS-0.58/lib/Net/DNS/Resolver/ Net-DNS-0.58/lib/Net/DNS/Resolver/Base.pm Net-DNS-0.58/lib/Net/DNS/Resolver/Cygwin.pm Net-DNS-0.58/lib/Net/DNS/Resolver/Recurse.pm Net-DNS-0.58/lib/Net/DNS/Resolver/UNIX.pm Net-DNS-0.58/lib/Net/DNS/Resolver/Win32.pm Net-DNS-0.58/lib/Net/DNS/Resolver.pm Net-DNS-0.58/lib/Net/DNS/RR/ Net-DNS-0.58/lib/Net/DNS/RR/A.pm Net-DNS-0.58/lib/Net/DNS/RR/AAAA.pm Net-DNS-0.58/lib/Net/DNS/RR/AFSDB.pm Net-DNS-0.58/lib/Net/DNS/RR/CERT.pm Net-DNS-0.58/lib/Net/DNS/RR/CNAME.pm Net-DNS-0.58/lib/Net/DNS/RR/DNAME.pm Net-DNS-0.58/lib/Net/DNS/RR/EID.pm Net-DNS-0.58/lib/Net/DNS/RR/HINFO.pm Net-DNS-0.58/lib/Net/DNS/RR/ISDN.pm Net-DNS-0.58/lib/Net/DNS/RR/LOC.pm Net-DNS-0.58/lib/Net/DNS/RR/MB.pm Net-DNS-0.58/lib/Net/DNS/RR/MG.pm Net-DNS-0.58/lib/Net/DNS/RR/MINFO.pm Net-DNS-0.58/lib/Net/DNS/RR/MR.pm Net-DNS-0.58/lib/Net/DNS/RR/MX.pm Net-DNS-0.58/lib/Net/DNS/RR/NAPTR.pm Net-DNS-0.58/lib/Net/DNS/RR/NIMLOC.pm Net-DNS-0.58/lib/Net/DNS/RR/NS.pm Net-DNS-0.58/lib/Net/DNS/RR/NSAP.pm Net-DNS-0.58/lib/Net/DNS/RR/NULL.pm Net-DNS-0.58/lib/Net/DNS/RR/OPT.pm Net-DNS-0.58/lib/Net/DNS/RR/PTR.pm Net-DNS-0.58/lib/Net/DNS/RR/PX.pm Net-DNS-0.58/lib/Net/DNS/RR/RP.pm Net-DNS-0.58/lib/Net/DNS/RR/RT.pm Net-DNS-0.58/lib/Net/DNS/RR/SOA.pm Net-DNS-0.58/lib/Net/DNS/RR/SPF.pm Net-DNS-0.58/lib/Net/DNS/RR/SRV.pm Net-DNS-0.58/lib/Net/DNS/RR/SSHFP.pm Net-DNS-0.58/lib/Net/DNS/RR/TKEY.pm Net-DNS-0.58/lib/Net/DNS/RR/TSIG.pm Net-DNS-0.58/lib/Net/DNS/RR/TXT.pm Net-DNS-0.58/lib/Net/DNS/RR/Unknown.pm Net-DNS-0.58/lib/Net/DNS/RR/X25.pm Net-DNS-0.58/lib/Net/DNS/RR.pm Net-DNS-0.58/lib/Net/DNS/Update.pm Net-DNS-0.58/lib/Net/DNS.pm Net-DNS-0.58/Makefile.PL Net-DNS-0.58/MANIFEST Net-DNS-0.58/META.yml Net-DNS-0.58/netdns.c Net-DNS-0.58/netdns.h Net-DNS-0.58/README Net-DNS-0.58/t/ Net-DNS-0.58/t/.resolv.conf Net-DNS-0.58/t/00-load.t Net-DNS-0.58/t/00-pod.t Net-DNS-0.58/t/00-version.t Net-DNS-0.58/t/01-resolver-env.t Net-DNS-0.58/t/01-resolver-file.t Net-DNS-0.58/t/01-resolver-opt.t Net-DNS-0.58/t/01-resolver.t Net-DNS-0.58/t/02-header.t Net-DNS-0.58/t/03-question.t Net-DNS-0.58/t/04-packet-unique-push.t Net-DNS-0.58/t/04-packet.t Net-DNS-0.58/t/05-rr-opt.t Net-DNS-0.58/t/05-rr-rrsort.t Net-DNS-0.58/t/05-rr-sshfp.t Net-DNS-0.58/t/05-rr-txt.t Net-DNS-0.58/t/05-rr-unknown.t Net-DNS-0.58/t/05-rr.t Net-DNS-0.58/t/06-update.t Net-DNS-0.58/t/07-misc.t Net-DNS-0.58/t/08-online.t Net-DNS-0.58/t/09-tkey.t Net-DNS-0.58/t/10-recurse.t Net-DNS-0.58/t/11-escapedchars.t Net-DNS-0.58/t/11-inet6.t Net-DNS-0.58/t/custom.txt Net-DNS-0.58/TODO Removing previously used /root/.cpan/build/Net-DNS-0.58 CPAN.pm: Going to build O/OL/OLAF/Net-DNS-0.58.tar.gz The libraries needed to support IPv6 transport have not been found. You will need recent versions of the IO::Socket::INET6 and Socket6 libraries (from CPAN). Testing if you have a C compiler and the needed header files.... In file included from compile.c:1: netdns.h:1:23: error: sys/types.h: No such file or directory In file included from compile.c:1: netdns.h:24: error: syntax error before ‘*’ token I cannot determine if you have a C compiler. I will install the perl-only implementation. You can force installation of the XS version with: perl Makefile.PL --xs You appear to be directly connected to the Internet. I have some tests that try to query live nameservers. Do you want to enable these tests? [y] y Checking if your kit is complete... Looks good Warning: prerequisite Digest::HMAC_MD5 1 not found. Warning: prerequisite Net::IP 1.2 not found. Writing Makefile for Net::DNS ---- Unsatisfied dependencies detected during [O/OL/OLAF/Net-DNS-0.58.tar.gz] ----- Digest::HMAC_MD5 Net::IP Shall I follow them and prepend them to the queue of modules we are processing right now? [yes] Running make test Delayed until after prerequisites Running make install Delayed until after prerequisites Running install for module Digest::HMAC_MD5 Running make for G/GA/GAAS/Digest-HMAC-1.01.tar.gz Checksum for /root/.cpan/sources/authors/id/G/GA/GAAS/Digest-HMAC-1.01.tar.gz ok Digest-HMAC-1.01/ Digest-HMAC-1.01/rfc2104.txt Digest-HMAC-1.01/Makefile.PL Digest-HMAC-1.01/lib/ Digest-HMAC-1.01/lib/Digest/ Digest-HMAC-1.01/lib/Digest/HMAC.pm Digest-HMAC-1.01/lib/Digest/HMAC_SHA1.pm Digest-HMAC-1.01/lib/Digest/HMAC_MD5.pm Digest-HMAC-1.01/Changes Digest-HMAC-1.01/t/ Digest-HMAC-1.01/t/rfc2202.t Digest-HMAC-1.01/README Digest-HMAC-1.01/MANIFEST Removing previously used /root/.cpan/build/Digest-HMAC-1.01 CPAN.pm: Going to build G/GA/GAAS/Digest-HMAC-1.01.tar.gz Checking if your kit is complete... Looks good Warning: prerequisite Digest::SHA1 1 not found. Writing Makefile for Digest::HMAC ---- Unsatisfied dependencies detected during [G/GA/GAAS/Digest-HMAC-1.01.tar.gz] ----- Digest::SHA1 Shall I follow them and prepend them to the queue of modules we are processing right now? [yes] Running make test Delayed until after prerequisites Running make install Delayed until after prerequisites Running install for module Digest::SHA1 Running make for G/GA/GAAS/Digest-SHA1-2.11.tar.gz Checksum for /root/.cpan/sources/authors/id/G/GA/GAAS/Digest-SHA1-2.11.tar.gz ok Digest-SHA1-2.11/ Digest-SHA1-2.11/README Digest-SHA1-2.11/t/ Digest-SHA1-2.11/t/bits.t Digest-SHA1-2.11/t/badfile.t Digest-SHA1-2.11/t/sha1.t Digest-SHA1-2.11/MANIFEST Digest-SHA1-2.11/fip180-1.html Digest-SHA1-2.11/SHA1.pm Digest-SHA1-2.11/typemap Digest-SHA1-2.11/fip180-1.gif Digest-SHA1-2.11/Changes Digest-SHA1-2.11/Makefile.PL Digest-SHA1-2.11/SHA1.xs Removing previously used /root/.cpan/build/Digest-SHA1-2.11 CPAN.pm: Going to build G/GA/GAAS/Digest-SHA1-2.11.tar.gz Checking if your kit is complete... Looks good Writing Makefile for Digest::SHA1 -- NOT OK Running make test Can't test without successful make Running make install make had returned bad status, install seems impossible Running make for G/GA/GAAS/Digest-HMAC-1.01.tar.gz Is already unwrapped into directory /root/.cpan/build/Digest-HMAC-1.01 CPAN.pm: Going to build G/GA/GAAS/Digest-HMAC-1.01.tar.gz -- NOT OK Running make test Can't test without successful make Running make install make had returned bad status, install seems impossible Running install for module Net::IP Running make for M/MA/MANU/Net-IP-1.25.tar.gz Checksum for /root/.cpan/sources/authors/id/M/MA/MANU/Net-IP-1.25.tar.gz ok Net-IP-1.25/ Net-IP-1.25/iptab Net-IP-1.25/META.yml Net-IP-1.25/IP.pm Net-IP-1.25/COPYING Net-IP-1.25/Changes Net-IP-1.25/t/ Net-IP-1.25/t/ExtUtils/ Net-IP-1.25/t/ExtUtils/TBone.pm Net-IP-1.25/t/ipv4.t Net-IP-1.25/t/ipv6.t Net-IP-1.25/ipcount Net-IP-1.25/MANIFEST Net-IP-1.25/Net-IP.spec.PL Net-IP-1.25/README Net-IP-1.25/Makefile.PL Removing previously used /root/.cpan/build/Net-IP-1.25 CPAN.pm: Going to build M/MA/MANU/Net-IP-1.25.tar.gz Checking if your kit is complete... Looks good Writing Makefile for Net::IP -- NOT OK Running make test Can't test without successful make Running make install make had returned bad status, install seems impossible Running make for O/OL/OLAF/Net-DNS-0.58.tar.gz Is already unwrapped into directory /root/.cpan/build/Net-DNS-0.58 CPAN.pm: Going to build O/OL/OLAF/Net-DNS-0.58.tar.gz -- NOT OK Running make test Can't test without successful make Running make install make had returned bad status, install seems impossible root@root-desktop:/home/karl/Desktop/sqlninja-0.1.0alpha# clear root@root-desktop:/home/karl/Desktop/sqlninja-0.1.0alpha# perl -MCPAN -e 'install Net::DNS::Nameserver' CPAN: Storable loaded ok Going to read /root/.cpan/Metadata Database was generated on Fri, 11 Aug 2006 01:34:36 GMT Running install for module Net::DNS::Nameserver Running make for O/OL/OLAF/Net-DNS-0.58.tar.gz CPAN: Digest::MD5 loaded ok Checksum for /root/.cpan/sources/authors/id/O/OL/OLAF/Net-DNS-0.58.tar.gz ok Scanning cache /root/.cpan/build for sizes Net-DNS-0.58/ Net-DNS-0.58/Changes Net-DNS-0.58/contrib/ Net-DNS-0.58/contrib/check_soa Net-DNS-0.58/contrib/check_zone Net-DNS-0.58/contrib/dnswalk.README Net-DNS-0.58/contrib/loc2earth.fcgi Net-DNS-0.58/contrib/loclist.pl Net-DNS-0.58/contrib/README Net-DNS-0.58/demo/ Net-DNS-0.58/demo/axfr Net-DNS-0.58/demo/check_soa Net-DNS-0.58/demo/check_zone Net-DNS-0.58/demo/example_recurse.pl Net-DNS-0.58/demo/mresolv Net-DNS-0.58/demo/mx Net-DNS-0.58/demo/perldig Net-DNS-0.58/demo/README Net-DNS-0.58/demo/trace_dns.pl Net-DNS-0.58/DNS.xs Net-DNS-0.58/lib/ Net-DNS-0.58/lib/Net/ Net-DNS-0.58/lib/Net/DNS/ Net-DNS-0.58/lib/Net/DNS/FAQ.pod Net-DNS-0.58/lib/Net/DNS/Header.pm Net-DNS-0.58/lib/Net/DNS/Nameserver.pm Net-DNS-0.58/lib/Net/DNS/Packet.pm Net-DNS-0.58/lib/Net/DNS/Question.pm Net-DNS-0.58/lib/Net/DNS/Resolver/ Net-DNS-0.58/lib/Net/DNS/Resolver/Base.pm Net-DNS-0.58/lib/Net/DNS/Resolver/Cygwin.pm Net-DNS-0.58/lib/Net/DNS/Resolver/Recurse.pm Net-DNS-0.58/lib/Net/DNS/Resolver/UNIX.pm Net-DNS-0.58/lib/Net/DNS/Resolver/Win32.pm Net-DNS-0.58/lib/Net/DNS/Resolver.pm Net-DNS-0.58/lib/Net/DNS/RR/ Net-DNS-0.58/lib/Net/DNS/RR/A.pm Net-DNS-0.58/lib/Net/DNS/RR/AAAA.pm Net-DNS-0.58/lib/Net/DNS/RR/AFSDB.pm Net-DNS-0.58/lib/Net/DNS/RR/CERT.pm Net-DNS-0.58/lib/Net/DNS/RR/CNAME.pm Net-DNS-0.58/lib/Net/DNS/RR/DNAME.pm Net-DNS-0.58/lib/Net/DNS/RR/EID.pm Net-DNS-0.58/lib/Net/DNS/RR/HINFO.pm Net-DNS-0.58/lib/Net/DNS/RR/ISDN.pm Net-DNS-0.58/lib/Net/DNS/RR/LOC.pm Net-DNS-0.58/lib/Net/DNS/RR/MB.pm Net-DNS-0.58/lib/Net/DNS/RR/MG.pm Net-DNS-0.58/lib/Net/DNS/RR/MINFO.pm Net-DNS-0.58/lib/Net/DNS/RR/MR.pm Net-DNS-0.58/lib/Net/DNS/RR/MX.pm Net-DNS-0.58/lib/Net/DNS/RR/NAPTR.pm Net-DNS-0.58/lib/Net/DNS/RR/NIMLOC.pm Net-DNS-0.58/lib/Net/DNS/RR/NS.pm Net-DNS-0.58/lib/Net/DNS/RR/NSAP.pm Net-DNS-0.58/lib/Net/DNS/RR/NULL.pm Net-DNS-0.58/lib/Net/DNS/RR/OPT.pm Net-DNS-0.58/lib/Net/DNS/RR/PTR.pm Net-DNS-0.58/lib/Net/DNS/RR/PX.pm Net-DNS-0.58/lib/Net/DNS/RR/RP.pm Net-DNS-0.58/lib/Net/DNS/RR/RT.pm Net-DNS-0.58/lib/Net/DNS/RR/SOA.pm Net-DNS-0.58/lib/Net/DNS/RR/SPF.pm Net-DNS-0.58/lib/Net/DNS/RR/SRV.pm Net-DNS-0.58/lib/Net/DNS/RR/SSHFP.pm Net-DNS-0.58/lib/Net/DNS/RR/TKEY.pm Net-DNS-0.58/lib/Net/DNS/RR/TSIG.pm Net-DNS-0.58/lib/Net/DNS/RR/TXT.pm Net-DNS-0.58/lib/Net/DNS/RR/Unknown.pm Net-DNS-0.58/lib/Net/DNS/RR/X25.pm Net-DNS-0.58/lib/Net/DNS/RR.pm Net-DNS-0.58/lib/Net/DNS/Update.pm Net-DNS-0.58/lib/Net/DNS.pm Net-DNS-0.58/Makefile.PL Net-DNS-0.58/MANIFEST Net-DNS-0.58/META.yml Net-DNS-0.58/netdns.c Net-DNS-0.58/netdns.h Net-DNS-0.58/README Net-DNS-0.58/t/ Net-DNS-0.58/t/.resolv.conf Net-DNS-0.58/t/00-load.t Net-DNS-0.58/t/00-pod.t Net-DNS-0.58/t/00-version.t Net-DNS-0.58/t/01-resolver-env.t Net-DNS-0.58/t/01-resolver-file.t Net-DNS-0.58/t/01-resolver-opt.t Net-DNS-0.58/t/01-resolver.t Net-DNS-0.58/t/02-header.t Net-DNS-0.58/t/03-question.t Net-DNS-0.58/t/04-packet-unique-push.t Net-DNS-0.58/t/04-packet.t Net-DNS-0.58/t/05-rr-opt.t Net-DNS-0.58/t/05-rr-rrsort.t Net-DNS-0.58/t/05-rr-sshfp.t Net-DNS-0.58/t/05-rr-txt.t Net-DNS-0.58/t/05-rr-unknown.t Net-DNS-0.58/t/05-rr.t Net-DNS-0.58/t/06-update.t Net-DNS-0.58/t/07-misc.t Net-DNS-0.58/t/08-online.t Net-DNS-0.58/t/09-tkey.t Net-DNS-0.58/t/10-recurse.t Net-DNS-0.58/t/11-escapedchars.t Net-DNS-0.58/t/11-inet6.t Net-DNS-0.58/t/custom.txt Net-DNS-0.58/TODO Removing previously used /root/.cpan/build/Net-DNS-0.58 CPAN.pm: Going to build O/OL/OLAF/Net-DNS-0.58.tar.gz The libraries needed to support IPv6 transport have not been found. You will need recent versions of the IO::Socket::INET6 and Socket6 libraries (from CPAN). Testing if you have a C compiler and the needed header files.... In file included from compile.c:1: netdns.h:1:23: error: sys/types.h: No such file or directory In file included from compile.c:1: netdns.h:24: error: syntax error before ‘*’ token I cannot determine if you have a C compiler. I will install the perl-only implementation. You can force installation of the XS version with: perl Makefile.PL --xs You appear to be directly connected to the Internet. I have some tests that try to query live nameservers. Do you want to enable these tests? [y] Checking if your kit is complete... Looks good Warning: prerequisite Digest::HMAC_MD5 1 not found. Warning: prerequisite Net::IP 1.2 not found. Writing Makefile for Net::DNS ---- Unsatisfied dependencies detected during [O/OL/OLAF/Net-DNS-0.58.tar.gz] ----- Digest::HMAC_MD5 Net::IP Shall I follow them and prepend them to the queue of modules we are processing right now? [yes] Running make test Delayed until after prerequisites Running make install Delayed until after prerequisites Running install for module Digest::HMAC_MD5 Running make for G/GA/GAAS/Digest-HMAC-1.01.tar.gz Checksum for /root/.cpan/sources/authors/id/G/GA/GAAS/Digest-HMAC-1.01.tar.gz ok Digest-HMAC-1.01/ Digest-HMAC-1.01/rfc2104.txt Digest-HMAC-1.01/Makefile.PL Digest-HMAC-1.01/lib/ Digest-HMAC-1.01/lib/Digest/ Digest-HMAC-1.01/lib/Digest/HMAC.pm Digest-HMAC-1.01/lib/Digest/HMAC_SHA1.pm Digest-HMAC-1.01/lib/Digest/HMAC_MD5.pm Digest-HMAC-1.01/Changes Digest-HMAC-1.01/t/ Digest-HMAC-1.01/t/rfc2202.t Digest-HMAC-1.01/README Digest-HMAC-1.01/MANIFEST Removing previously used /root/.cpan/build/Digest-HMAC-1.01 CPAN.pm: Going to build G/GA/GAAS/Digest-HMAC-1.01.tar.gz Checking if your kit is complete... Looks good Warning: prerequisite Digest::SHA1 1 not found. Writing Makefile for Digest::HMAC ---- Unsatisfied dependencies detected during [G/GA/GAAS/Digest-HMAC-1.01.tar.gz] ----- Digest::SHA1 Shall I follow them and prepend them to the queue of modules we are processing right now? [yes] Running make test Delayed until after prerequisites Running make install Delayed until after prerequisites Running install for module Digest::SHA1 Running make for G/GA/GAAS/Digest-SHA1-2.11.tar.gz Checksum for /root/.cpan/sources/authors/id/G/GA/GAAS/Digest-SHA1-2.11.tar.gz ok Digest-SHA1-2.11/ Digest-SHA1-2.11/README Digest-SHA1-2.11/t/ Digest-SHA1-2.11/t/bits.t Digest-SHA1-2.11/t/badfile.t Digest-SHA1-2.11/t/sha1.t Digest-SHA1-2.11/MANIFEST Digest-SHA1-2.11/fip180-1.html Digest-SHA1-2.11/SHA1.pm Digest-SHA1-2.11/typemap Digest-SHA1-2.11/fip180-1.gif Digest-SHA1-2.11/Changes Digest-SHA1-2.11/Makefile.PL Digest-SHA1-2.11/SHA1.xs Removing previously used /root/.cpan/build/Digest-SHA1-2.11 CPAN.pm: Going to build G/GA/GAAS/Digest-SHA1-2.11.tar.gz Checking if your kit is complete... Looks good Writing Makefile for Digest::SHA1 -- NOT OK Running make test Can't test without successful make Running make install make had returned bad status, install seems impossible Running make for G/GA/GAAS/Digest-HMAC-1.01.tar.gz Is already unwrapped into directory /root/.cpan/build/Digest-HMAC-1.01 CPAN.pm: Going to build G/GA/GAAS/Digest-HMAC-1.01.tar.gz -- NOT OK Running make test Can't test without successful make Running make install make had returned bad status, install seems impossible Running install for module Net::IP Running make for M/MA/MANU/Net-IP-1.25.tar.gz Checksum for /root/.cpan/sources/authors/id/M/MA/MANU/Net-IP-1.25.tar.gz ok Net-IP-1.25/ Net-IP-1.25/iptab Net-IP-1.25/META.yml Net-IP-1.25/IP.pm Net-IP-1.25/COPYING Net-IP-1.25/Changes Net-IP-1.25/t/ Net-IP-1.25/t/ExtUtils/ Net-IP-1.25/t/ExtUtils/TBone.pm Net-IP-1.25/t/ipv4.t Net-IP-1.25/t/ipv6.t Net-IP-1.25/ipcount Net-IP-1.25/MANIFEST Net-IP-1.25/Net-IP.spec.PL Net-IP-1.25/README Net-IP-1.25/Makefile.PL Removing previously used /root/.cpan/build/Net-IP-1.25 CPAN.pm: Going to build M/MA/MANU/Net-IP-1.25.tar.gz Checking if your kit is complete... Looks good Writing Makefile for Net::IP -- NOT OK Running make test Can't test without successful make Running make install make had returned bad status, install seems impossible Running make for O/OL/OLAF/Net-DNS-0.58.tar.gz Is already unwrapped into directory /root/.cpan/build/Net-DNS-0.58 CPAN.pm: Going to build O/OL/OLAF/Net-DNS-0.58.tar.gz -- NOT OK Running make test Can't test without successful make Running make install make had returned bad status, install seems impossible
checking for gcc... gcc checking for C compiler default output file name... configure: error: C compiler cannot create executables See `config.log' for more details. Can't locate config.pl in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.8.7 /usr/local/share/perl/5.8.7 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl .) at Makefile.PL line 41. Running make test Make had some problems, maybe interrupted? Won't test Running make install Make had some problems, maybe interrupted? Won't install Running make for M/MO/MONDEJAR/IO-Socket-INET6-2.51.tar.gz Is already unwrapped into directory /root/.cpan/build/IO-Socket-INET6-2.51
