I don't think so. Launching any GUI app with kdesudo preserves the users environment. There are some quirks (by design?) where you need/must launch a System Settings module 'as root' in order for changes to be preserved between reboots. That's why I suggested this approach. If it works, it works. If it doesn't, then there is some other issue as the root cause (no pun intended) of the OP's problem.
Avoid a KDEctomy: Musings on sudo and kdesudo
"It is a capital mistake to theorize before one has data." - Sherlock HolmesTags: None
Originally posted by Snowhog View PostI don't think so. Launching any GUI app with kdesudo preserves the users environment. There are some quirks (by design?) where you need/must launch a System Settings module 'as root' in order for changes to be preserved between reboots. That's why I suggested this approach. If it works, it works. If it doesn't, then there is some other issue as the root cause (no pun intended) of the OP's problem.
Code:kdesudo konsole # echo $HOME /root
I stand corrected.Windows no longer obstructs my view.
Pan-Galactic QuordlepleenSo Long, and Thanks for All the Fish
- Jul 2011
- 9524
- Seattle, WA, USA
- Send PM
Inconsistencies...
Code:steve@t520:~$ [B]whoami[/B] steve steve@t520:~$ [B]echo $HOME[/B] /home/steve steve@t520:~$ [B]pwd[/B] /home/steve steve@t520:~$ [B]sudo konsole[/B] root@t520:~# [B]whoami[/B] root root@t520:~# [B]echo $HOME[/B] /home/steve root@t520:~# [B]pwd[/B] /home/steve root@t520:~# [B]exit[/B] steve@t520:~$ [B]kdesudo konsole[/B] root@t520:/home/steve# [B]whoami[/B] root root@t520:/home/steve# [B]echo $HOME[/B] /root root@t520:/home/steve# [B]pwd[/B] /home/steve root@t520:/home/steve# [B]exit[/B] steve@t520:~$
- Jul 2011
- 9524
- Seattle, WA, USA
- Send PM
Yeah, the difference lies in the value of $HOME. This is also interesting, to see how $XAUTHORITY changes.
Code:steve@t520:~$ [B]sudo env[/B] TERM=xterm LS_COLORS={...snipped...} PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin LANG=en_US.UTF-8 HOME=/home/steve LANGUAGE= DISPLAY=:0 XAUTHORITY=/tmp/kde-steve/xauth-1000-_0 SHELL=/bin/bash LOGNAME=root USER=root USERNAME=root MAIL=/var/mail/root SUDO_COMMAND=/usr/bin/env SUDO_USER=steve SUDO_UID=1000 SUDO_GID=1000 steve@t520:~$ [B]kdesudo env[/B] LANGUAGE= PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin LANG=en_US.UTF-8 DISPLAY=:0 XAUTHORITY=/tmp/kdesudo-Z27358-xauth TERM=xterm LS_COLORS={...snipped...} HOME=/root SHELL=/bin/bash LOGNAME=root USER=root USERNAME=root MAIL=/var/mail/root SUDO_COMMAND=/usr/bin/env SUDO_USER=steve SUDO_UID=1000 SUDO_GID=1000
- Jul 2011
- 9524
- Seattle, WA, USA
- Send PM
Originally posted by diblthe user is done logging in to KDE
Originally posted by SteveRileyYeah, the difference lies in the value of $HOME.
One can run GUI apps with sudo using root's $HOME, but that usually requires a bit of tinkering, something like (but not limited to):
sudo -H XAUTHORITY=$HOME/.Xauthority konsole
Then again, this has very little to do with the topic at hand, and probably belongs in another topic
Originally posted by diblRight -- when ~/.Xauthority becomes owned by root, as a result of "sudo kate" or something like that, the user is done logging in to KDE. A painful lesson learned the hard way by many a Kubuntu user, including yours truly.
(I'll admit I'm not 100% on that, though, I don't use sudo like that so I don't really have empirical evidence)
Perhaps mod could split us thread privateers onto a new thread, so we don't mask the OP's problem?
- Jul 2011
- 9524
- Seattle, WA, USA
- Send PM
He's ba-a-a-ack!Windows no longer obstructs my view.
- Jul 2011
- 9524
- Seattle, WA, USA
- Send PM
Potato, patato. You say Amond, I say almond.Windows no longer obstructs my view.
