Swap (and low memory) performance
    Another possibility is IRQ problems. Powertop should help determine how your interrupts are working.
    Here's mine:
    226 wakeups/second
          0.8 ms/s      61.2        Timer          tick_sched_timer
                 15.8 ms/s      24.8        Process        /usr/bin/ksysguard
                128.4 µs/s      19.3        kWork          ieee80211_iface_work
                  3.6 ms/s      10.3        Process        /usr/bin/X :0 vt7 -br -nolisten tcp -aut
                  1.4 ms/s       9.8        Process        dbus-daemon --system --fork --activation
                278.7 µs/s      10.0        Process        /usr/sbin/bumblebeed --use-syslog
                 95.2 µs/s       8.3        Process        [rtsx-polling]
                197.8 µs/s       7.7        Timer          hrtimer_wakeup
                  1.1 ms/s       7.1        Process        kwin -session 101b7188189177000134408930
                  2.3 ms/s       6.2        Process        /usr/bin/python -O /usr/share/wicd/daemo
                  6.3 ms/s       4.1        Process        ksysguardd
                  0.9 ms/s       5.9        Interrupt      [6] tasklet(softirq)
                144.6 µs/s       4.8        Process        [ksoftirqd/4]
                  0.9 ms/s       4.3        Process        /usr/bin/python -O /usr/share/wicd/daemo
                  1.7 ms/s       2.7        Process        /usr/bin/plasma-desktop
                378.4 µs/s       2.4        Process        /usr/bin/konsole
                186.9 µs/s       2.2        Process        /usr/sbin/mysqld --defaults-file=/home/j
                 84.4 µs/s       2.0        Process        /usr/lib/chromium-browser/chromium-brows
                  1.9 ms/s       1.2        Process        wicd
      This problem seems to have stopped for me. For a while at least!
      Originally posted by SecretCode View Post
      ... I find that it's when paging out/in is taking place that the system grinds to a halt. ...
      Keen to hear from others as well, if anyone finds that performance is bearable when the system starts swapping.
      It occurred to me that I hadn't experienced such an usable slowdown for a while - but nevertheless I was using some swap - and of course there was some performance impact, but no more than regular IO. Presumably some kernel update has fixed some specific issue. I certainly haven't done anything concrete to address it.
        As noted an SSD gives great bang for the buck. However some dx'ing is needed per the swap usage. I regularly run three different Browsers with 4 to 8 tabs open, a VM, at least one instance of Dolphin. And probably a partridge in a pear tree if I bothered to look closely. I have never seen more than 3.4 GB of my 4 GB of RAM used. I have yet to see swap (a partition) used at all. Zero. Zilch. Nada. I run KDE all the time. I have an old PC. I'm very happy with the responsiveness of my system except for the amount of time that it takes to give me a logon after a lock either a manual one or a screensaver one. It takes a couple of seconds.
        I am still running HDDs, both 7200 rpm. Both SATA II.
        Of course I'm getting slower also, but that's for another thread.
        GigaByte GA-965G-DS3, Core2Duo at 2.1 GHz, 4 GB RAM, ASUS DRW-24B1ST, LiteOn iHAS 324 A, NVIDIA 7300 GS, 500 GB and 80 GB WD HDD
          The only reason I keep a swap partition is for hibernation.
            my swap partition gets used quite often ,,,, just watching a vid or DVD will use a little and when recoding audio/video .
            my system has 4Gig of RAM
            see just got done watching a 3+ Hr DVD
            vinny@Vinnys-HP-G62:~$ free
            total used free shared buffers cached
            Mem: 3844396 3619436 224960 0 2020184 495592
            -/+ buffers/cache: 1103660 2740736
            Swap: 4096536 2384 4094152
