You win the award for having the slowest drive so far.
And quite possibly also for having the longest hostname
ATA device, with non-removable media Model Number: WDC WD5000AAKX-001CA0 Serial Number: WD-WMAYU8671853 Firmware Revision: 15.01H15 Transport: Serial, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
/dev/sda: Timing buffered disk reads: 392 MB in 3.01 seconds = 130.15 MB/sec
ATA device, with non-removable media Model Number: INTEL SSDSC2CW060A3 Serial Number: CVCV1532055W060AGN Firmware Revision: 400i Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
/dev/sdb: Timing buffered disk reads: 928 MB in 3.00 seconds = 309.27 MB/sec
sigpic |
/dev/sda: Timing buffered disk reads: 52 MB in 3.07 seconds = 16.95 MB/sec
sudo hdparm -t /dev/sda /dev/sda: Timing buffered disk reads: 570 MB in 3.01 seconds = 189.66 M
/dev/sda: ATA device, with non-removable media Model Number: KINGSTON SV200S364G Serial Number: Z19A30MEKATK Firmware Revision: E120506a Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0 Standards: Supported: 9 8 7 6 5 Likely used: 9 Configuration: Logical max current cylinders 16383 16383 heads 16 16 sectors/track 63 63 -- CHS current addressable sectors: 16514064 LBA user addressable sectors: 125045424 LBA48 user addressable sectors: 125045424 Logical Sector size: 512 bytes Physical Sector size: 512 bytes Logical Sector-0 offset: 0 bytes device size with M = 1024*1024: 61057 MBytes device size with M = 1000*1000: 64023 MBytes (64 GB) cache/buffer size = unknown Form Factor: 2.5 inch Nominal Media Rotation Rate: Solid State Device
