Hello all,
I installed IBUS on my Kubuntu 12.04 in order to use Chinese input. Everything works smoothly. Just one kind of weird problem came up after install IBUS. I can not type for example ë ê õ anymore. If I try make the accents, sometimes (like now) it doesn't appear at all. Before I had the problem, if I use the accents, it directly writes them, without waiting the letter to put it on. The most weird about whole situation though is the fact that in the terminal and in the test area for keyboard settings it works fine. In Ibus I set the setting "use system keyboard layout"
Somebody have any idea what could be the problem?
Thanks for helping me
Robin
Robin
