This is a long shot, but...
Gimp-2.8 works great, downloaded from:
sudo add-apt-repository ppa
tto-kesselgulasch/gimp
sudo apt-get update
sudo apt-get install gimp
Only thing is this: gtk-2 themes no longer work, it needs gtk-3.
Newer gtk3 themes use a different scheme than the gtkrc file,
which is what gimp still uses. Older ones still have gtkrc files, and work fine.
Anyone know of a gtk-3 dark orange theme (like what is used by darktable) that
will work for gimp-2.8? The old gtk-2 clearlooks-orange does not work.
sudo apt-get update
