512 byte problem
    512 byte problem
    Today I attempted to do what I've done many times previously: clone my internal HDD to my external USB HDD. I use Clonezilla, and today it refused, saying that the source HDD was larger than the target HDD. Huh?? My internal drive 'grew' or my external drive 'shrunk'!? Not likely. However, fdisk -l does show a 512 byte difference between the two HDDs. How did this happen!?
    Disk /dev/sda: 500.1 GB, 500107862016 bytes
    255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
    Units = sectors of 1 * 512 = 512 bytes
    Disk identifier: 0xf4aea3a7
    Device Boot Start End Blocks Id System
    /dev/sda1 * 2048 8390655 4194304 82 Linux swap / Solaris
    /dev/sda2 8392702 417349631 204478465 5 Extended
    /dev/sda5 8392704 39849983 15728640 83 Linux
    /dev/sda6 39852032 144709631 52428800 83 Linux
    /dev/sda7 144711680 176168959 15728640 83 Linux
    /dev/sda8 176171008 281028607 52428800 83 Linux
    /dev/sda9 281030656 312487935 15728640 83 Linux
    /dev/sda10 312489984 417347583 52428800 83 Linux
    Disk /dev/sdc: 500.1 GB, 500107861504 bytes
    255 heads, 63 sectors/track, 60801 cylinders, total 976773167 sectors
    /dev/sdc1 63 976768064 488384001 83 Linux
    Both HDDs have the same geometry: 255 heads, 63 sectors/track, 6081 cylinders, but there is a one sector difference (512 bytes) between them. If the geometry's are the same, how can a sector be missing?
    The only thing I can think of off hand is that one sector got marked bad by the drive via SMART. You can check the smart status of the drive w/ the "smartctl" command.
