Well, since the Kubu drive went south, it was JUST 6 years old!!
I had the thought that I'd try running Kubu from a flash drive.
I did that once before, with some OS I don't remember, maybe about three years ago. As I remember the distro had specific stuff and really promoted running from a USB drive, maybe it was DSL or something. But it was "sluggish" and didn't find some hardware as I remember.
Anywho...I checked the info on the Kubu d/l page. I have a Sandisk 16 gig that I'll format to FAT and even though I have an AMD 64 would probably do a AMD 32 install.
What I would be planning to do is to run it straight from the usb drive permanently, like in LTS mode, and staying on 24 hrs/ day..
so questions:
It will HAVE to be wireless the machine presently works fine wirelessly using Oneric.
Are there folks that have specifically done this and are there any things of which I should be aware?
Do Oneric, Precise?
I really would like to use the present Remastersys of my previously tweaked install....so?
woodsmoke
so questions:
Do Oneric, Precise?
woodsmoke
