Strigi failed to index how to fix it and why it stopped working.
    The "fix" is to use Konqueror as root and navigate to:
    home/.kde/share/apps
    and delete/move to trash the whole folder named "nepomuk".
    Then restart the system and nepomuk will make the folder anew and restart indexing.
    The gentle reader can now stop reading.
    How I had the problem
    I changed the Kubu hard drive to another computer which had only one gig of memory so the indexer was using a lot of memory.
    Also I was using a bigger video card with not enough memory and that was hogging stuff also.
    THEN.. I followed DYK's instructions on how to install and run Koceansaver, also I tried to "make install" two other screensavers ... all of these folders had a LOT OF images, a lot of large images, etc. etc.
    Basically nepomuk/strigi was swamped and when I started testing the setup of Koceansaver the system locked up.
    Something happened to strigi at that time that set it into a loop trying to index what was in the extracted files of the Koceansaver tar.
    I watched processes and virtuoso-t was going nuts and it was right after I did all the installations and the attempts so, I deleted the nepomuk folder, restarted and all was well.
    However, the indexing is still slow from lack of memory so I will buy a stick tomorrow, but deleting the folder and then restarting has at least stabilized the system and the indexing does work, it is just slow.
    Hope this helps a little.
    woodsmoke
