I recently had to re-download Windows XP to another machine in the house. This took time, it was frustrating! When I finally got the set-up to start, the set-up asked me for Windows XP service pack 2. I did not have the CD for that one. I know I could download the SP2 on my laptap and I wanted to transfer the file to my flash/thumb drive. First, I had to partition the flash drive. Then, as I read, I had to install mbr to the flash drive. This is where I met with a problem.
I type this in the terminal using a kubuntu 9.10 running on another computer but not fully-installed in the computer. Here are the commands:
ubuntu@ubuntu:~$ sudo su
root@ubuntu:/home/ubuntu# apt-get install mbr
Reading package lists... Done
Building dependency tree
mbr
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 23.0kB of archives.
After this operation, 94.2kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com karmic/main mbr 1.1.10-2 [23.0kB]
Fetched 23.0kB in 0s (32.6kB/s)
Selecting previously deselected package mbr.
(Reading database ... 90576 files and directories currently installed.)
Unpacking mbr (from .../archives/mbr_1.1.10-2_i386.deb) ...
Processing triggers for man-db ...
Setting up mbr (1.1.10-2) ...
root@ubuntu:/home/ubuntu# fdisk -l
That's where I ran into a problem. I don't know which file my flash/thumb drive is on.
Without inserting the flash drive into computer, this was the outcome of that last command.
Disk /dev/sda: 20.0 GB, 20020396032 bytes
240 heads, 63 sectors/track, 2586 cylinders
Units = cylinders of 15120 * 512 = 7741440 bytes
Disk identifier: 0xc70ac70a
Device Boot Start End Blocks Id System
/dev/sda1 * 1 2585 19542568+ 7 HPFS/NTFS
With the flash/thumb drive inserted on the computer, this is what I found.
Disk /dev/sdb: 1029 MB, 1029701632 bytes
5 heads, 4 sectors/track, 100556 cylinders
Units = cylinders of 20 * 512 = 10240 bytes
Disk identifier: 0xfeba425d
/dev/sdb1 4 97588 975840+ c W95 FAT32 (LBA)
P.S. root@ubuntu:/home/ubuntu# install-mbr/dev/sdb
bash: install-mbr/dev/sdb: No such file or directory
root@ubuntu:/home/ubuntu# install-mbr/dev/sdb1
bash: install-mbr/dev/sdb1: No such file or directory
I have tried to install mbr to my file this way, and it didn't work.
Did I partition my drive wrong? What letter will tell me which one is my thumb drive so I can hit:
install-mbr/dev/sdx (x replacing my drive) so I can install Windows XP Service pack 2 to my thumb drive through another program. Please help, very lost and confused now. Thank you!
mbr
