amarok data base message
    The amarok database reported the following errors: GREPME MySQL-server query failed! (2002) Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) on na. In most cases you will need to resolve these errors before Amarok will run properly. ...
    can someone explain this to me and if there is a fix
    thanks
