I convinced a client to ditch Vista and try Linux because her Vista system was borked and after many hours of trying to repair it I never figured out what was causing the problem. I attached her hard drive to my maintenance computer which runs Xubuntu and copied her Documents and Settings folder to the hard drive on my computer so that after wiping the drive preparing for the Linux Mint install I could copy back all of the pictures, documents, etc, to the new install. I thought I had copied them. I did this using Dolphin. In a split frame I merely dragged and dropped the folder to a directory on my hard drive. It seemed to work fine. It did this with a amazing speed and that should have clued me to the problem. It did not actually copy the folder, it merely created a symbolic link to the folder in the directory. When I went to the new directory after wiping the hard drive, all I got was a broken link. Woe is me.
I do have another backup I made on a DVD while I was trying to repair the Vista problem and it has everything, but now I have to find a computer running Vista to restore the backup. I don't have any computers running Vista or Win7 that I could use to do this. The backup is in a windows executable file.
I feel so stupid.
I feel so stupid.
