I have changed the hostname of my recent Kubuntu 11.04 install by using Alt-F2 "kdesudo kate /etc/hostname" then rebooted my laptop. It has worked just fine and I can see the new hostname. However the /etc/hosts file still reflects the old name. Should I change it there as well?
Changing Hostname
Re: Changing Hostname
Originally posted by sithlord48i think you also could have just used the "hostname" command to set both of those entries.
[code=run in konsole]
sudo hostname new_host_name
[/code]
