Dear every merry penguin
I have a friend with a problem, and the problem is not that he uses Windows, but that the computer seems to shut down arbitrarily, but the fans are still on. The first time the problem occurred was while watching a film-file on the computer.
The following systems occurs:
Temperature seems not to be a problem, since one indicator indicates that the temperature is only 42 degrees Celsius. If the computer is not used but still turned on, nothing happens. Approximately 30 minutes of use, the computer enters the above described mode with an inactive motherboard and running fans.
I do not know if it has any relevance, but it is using Windows 7, however, I do not believe it is a viral problem since it does not gloat when it turns of.
- Screen is on but searching for a signal (which might not be there - it is not an onboard graphic card).
- There is no sound (onboard graphic card).
- The fans are still running.
