OK. Took a chance on the DVD I downloaded yesterday ahead of release for 11.04. Believe it or not that was a good gamble. MD5s compare. So, the help I need is I want to export my current installed files from APT for 10.10 and use it to reload in 11.04. There was a post here a couple of weeks ago that explained how to do that and now I can't find it. Anyone that knows how or can point me to the original post I'd more than appreciate it! Thanks!
Upgrade Help [SOLVED]
Re: Upgrade Help
Originally posted by MoonRiseOK. Took a chance on the DVD I downloaded yesterday ahead of release for 11.04. Believe it or not that was a good gamble. MD5s compare. So, the help I need is I want to export my current installed files from APT for 10.10 and use it to reload in 11.04. There was a post here a couple of weeks ago that explained how to do that and now I can't find it. Anyone that knows how or can point me to the original post I'd more than appreciate it! Thanks!
Let's do all the work in your Documents directory so we can find it later.
cd Documents
dpkg --get-selections > installed-programs.txt
This will make a list of all your installed programs and dump it to a file called installed-programs.txt - it will also list any programs from a default install that you've removed. Back the file up to a safe place - your home directory should be backed up anyway, right?
Okay, then you do your install. We're gonna assume that installed-programs.txt is still in your Documents directory. Once you log on with your shiny new os, do
cd Documents
sudo dpkg --set-selections < installed-programs.txt
sudo apt-get dselect-upgrade
All done. Notice that you don't need to be root to make the list but you *do* have to be root to set the selections or do the upgrade. Also, notice that the redirect symbols point in opposite directions - in the first one you're writing to a text file, in the second one you're reading from it.
Enjoy
edit: If you had any nonstandard repos in your old configuration you probably want to add those and update apt's cache first.
cheers -we see things not as they are, but as we are.
-- anais nin
Re: Upgrade Help
Anytime. I would be interested in what you thought of the whole operation once you get it done.
I run that dump of installed packages as a nightly cron job on both my machines. It's saved my bacon more than once
-- anais nin
Re: Upgrade Help
Did great! Basically my laptop is back as it was except for a few odd and ends that were manually installed. Thanks! This is a very simple means of updating other than it took forever to install all 700 packages I had extra.
Re: Upgrade Help
Originally posted by MoonRiseDid great! Basically my laptop is back as it was except for a few odd and ends that were manually installed. Thanks! This is a very simple means of updating other than it took forever to install all 700 packages I had extra.
The only program I use that I haven't been able to find in someone's PPA is LaCie's Lightscribe editor, which in my book is the best one out there for Linux.
But - considering how much of a pain Lightscribe is in the first place - and that nobody makes a silver or white Lightscribe disc, I usually just use a Sharpie unless I'm doing something really importantwe see things not as they are, but as we are.
-- anais nin
Re: Upgrade Help
>Originally posted by MoonRiseMinor issues with the desktop. Plasma is having issues. May have to wipe out ~\.kde. Will wait a while on that. Hate to have to redo all settings. The process was still flawless going this route so, yea!we see things not as they are, but as we are.
-- anais nin
Re: Upgrade Help
Actually that is what I meant. Went ahead and did that. Was getting really bad. That fixed it! Perfect system! Both machine in under 5 hours each and that is with 700+ apps/dependencies downloaded! That actual OS took about 30 minutes. I can say that 11.04 does seem snappier even on my laptop.
Re: Upgrade Help [SOLVED]
On my Toshiba Satellite P105-S6147, Natty runs very nicely.Windows no longer obstructs my view.
