Hello,
i have a problem to setup the resolutions for my screens. I'm using the 1024 MB ATI Radeon HD 5670. It has a DVI, a HDMI and a displayport. I'm using the HDMI and DVI ports and the VGA port of my onboard graphic-chip. The display at the HDMI port should use the 1920x1080 resolution, the other should use 1024x768. The screen at the onboard-chip shows nothing but this isn't the main issue. The problem is, i can configure the resolution and the position of the screens, but when I reboot it's reseted. I have no xorg.conf in my /etc/X11 folder and i have no idea how to set one up.
Please excuse my bad english, i'm from germany and english isn't my best subject. If i overlooked any thread, that holds a solution for my problem it would be nice if you could give me a link. If you need any more informations pleas tell me and i'll do my best to find it out.
Greez and thanks in advance.
The false priest
The false priest
