Sceencast for kubuntu
    I want to use a desktop recorder for my kubuntu but I didn't find any suitable one for me, because I want a recorder generates small size records (just like instant demo).
    could you please help me?
    I tested the following software but they didn't fit my needs:
    recordmydesktop, xvidcap, istanbul, kazam & recorditnow
    I found byzanz most suitable for me although it doesn't support sound for small size records (gif format), but in case there are no alternative to instantdemo in Linux
    how can I use byzanz in KDE without need to open the terminal (I prefer GUI softwares)?
    Re: Sceencast for kubuntu
    Well, there is one nice program, but unfortanetly, it's GNOME only But if you don't care about that, than here it is: http://www.webupd8.org/2010/09/try-k...plication.html
    Edit: Never mind. I'm sorry for misreading your post. You already tried it. In that case, I dunno of any alternatives except for recormydesktop, which you also tried.
    Most important laptop specs (this is my main computer, with Kubuntu on it):<br /><br />4096MB RAM (DDR2)<br />500GB Hard Disk<br />ATI Mobility Radeon 4570HD Videocard with 512MB GDDR3 RAM, up to 2280MB VRAM<br />Intel® Core™ 2 Duo-processor T6600<br /><br />OS: Kubuntu 10.10
      old article, but--
      http://www.linuxhaxor.net/?p=815
      Registered Linux User 545823
        I personally never had much luck with GUI apps for this.....but if you have ffmpeg installed then something like this should work
        ffmpeg -r 30 -s 1024x768 -f x11grab -i :0.0 -f oss -i /dev/dsp -vcodec msmpeg4v2 -qscale 2 filename.avi
          Vinny,
          wow!!! That is so cool. I've already made an alias in my .bashrc for that line.
          And, sorry to hijack but the resulting avi file is huge. Have you got another quick CLI command to compress it?
            ffmpeg doesn't solve the issue because it's not suitable for small size screenscasts, it's just like any traditional recorder (records full frames) where instantdemo or byzanz/gif records backgrounds with differences of them for that you'll find screencast size very small by comparing with any encoding.
