Does Kubuntu normally have anything in its Power Management settings to "Spin down hard disks when possible" if you have drives on your system not being used at the time? Ubuntu has a checkbox for that, although, I do not know what the timing is for it.
The last time I used KDE was SuSE 8.2 and I have not run Kubuntu before. So I was just trying out Kubuntu natty installed on 8 GB USB and was not sure if that just was not implemented yet in that, or if Kubuntu does not normally have that setting.
It is simple enough to add /sbin/hdparm -S 60 /dev/sda to /etc/rc.local if you are familiar with Linux and that command, but novices may not be aware of that. I don't really need to do that with sdb anyway which is an SSD (currently Ubuntu natty).
