I know apps like Konqueror and Dolphin have an option that lets you hide or show hidden files but how do I make it impossible for common users to visualize them at all?
How do I keep hidden files hidden from common OS users?
Re: How do I keep hidden files hidden from common OS users?
The "hidden" files are not a security thing they are convenience thing.
> Listing Filenames and Attributes in UNIX
Hidden Files
Filenames in UNIX can contain almost any character and start with almost any character. However, filenames starting with a "." (dot, period) are often called hidden files because they don't show up in a regular ls command and you don't get rid of them with a rm * command. It is common for UNIX tools to create "dot" files for temporary files and to maintain control and history information. Users are also expected to create them as configuration files.
If you want to "hide" things from the common users you could use the encryption.
Simply right click a file/directory > Actions > Encrypt ...
[img width=400 height=278]http://img87.imageshack.us/img87/3261/encrypt.jpg[/img]
The service menu is from the package: kgpg
Description: encryption utility for KDE 4
Kgpg manages cryptographic keys for the GNU Privacy Guard, and can encrypt,
decrypt, sign, and verify files. It features a simple editor for applying
cryptography to short pieces of text, and can also quickly apply cryptography
to the contents of the clipboard.
This package is part of the KDE 4 utilities module.
Homepage: http://www.kde.org/
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
More > Encrypted Filesystem HowtoBefore you edit, BACKUP !
Why there are dead links ?
2. Thread: Lost Information
Hmmmmmm.
If, after all the existing dot files are encrypted, one of these commoners runs a package like audacity or devede for the first time, won't it create a new, unencrypted .audacity or .devede file? It seems the sysadmin will be chasing the users every day to see if they have created more dot files.
As i said the "hidden" files are not a security thing they are convenience thing.
You can't hide things from the users if they have an access to the machine. They can start the machine from an external media (usb stick) and mount the partitions. Then they can read,write or modify the "hidden" data.
Convenient view (at here).
[img width=400 height=329]http://img695.imageshack.us/img695/7600/clean0.png[/img]
Showing everything.
[img width=400 height=394]http://img148.imageshack.us/img148/3467/messyf.jpg[/img]
Originally posted by Rog131As i said the "hidden" files are not a security thing they are convenience thing.
@kyonides -- I think you have to make your users promise not to mess with dot files, before they get a login.
In the past, with the Kubuntu 6.10, there was an experiment to hide the root directories (> FF):
Hidden Files
Some may have noticed that in the Edgy release, when you would open the "Save" or "Open" dialog, all you would see is your home and media directories, due to the root directory and subdirectories being hidden.
> the /home and /media thing is not a bug, it's on purpose, you can still
> access the directory you like like by entering it in the file dialog.
Well, if this is the case then they've crippled a well working system beyond a level not even the Evil from Redmond would expect of it's users!Before you edit, BACKUP !
Right -- all attempts at "idiot-proofing" have such limits.
Happily, the only thing that will be damaged by fooling around with dot files is the idiot's own /home folder and session. And then, kyonides can charge $50.00 to fix the idiot's login (by secretly deleting all the dot files and making him log in again).
See, there is justice!
I thought someone would suggest something related to Kiosk but I guess I was wrong from the very beginning. I already knew the dots didn't appear in Linux to provide some extra security level but just to make some common files invisible. I hope that in a network environment I could just use a script that could delete the dotted files at logout and recreat it during the setup or login process.Multibooting: Kubuntu Noble 24.04
Before: Jammy 22.04, Focal 20.04, Precise 12.04 Xenial 16.04 and Bionic 18.04
Win XP, 7 & 10 sadly
Using Linux since June, 2008
The hidden files are only "secure" from the most novice of users. Rog has it right - it's really a convenience option rather than the windows idea of "secret" files.
Originally posted by kyonidesI thought someone would suggest something related to Kiosk but I guess I was wrong from the very beginning. I already knew the dots didn't appear in Linux to provide some extra security level but just to make some common files invisible. I hope that in a network environment I could just use a script that could delete the dotted files at logout and recreat it during the setup or login process.
And why would you want to delete all the dot files? Are we talking about a multitude of users using one account or does everyone receive their own account?
Whatever, as for deleting whatever at logout I suppose you could write a script to suit your needs and stick it in ~/.kde/shutdown
Also, to adjust the desktop experience of a new user you play with /etc/skelOnce your problem is solved please mark the topic of the first post as SOLVED so others know and can benefit from your experience! / FAQ
