speed on the net
    speed on the net
    how do you get more speed on a dsl conection?
    Re: speed on the net
    Have a friend who works for your provider log into the DSLAM and open up your line. Not that I would know about that sort of thing....:P
      omg that was funny.
        If you use firefox, you can do the following things:
        In the Konsole (or another terminal emulator) type:
        kdesu kwrite /etc/modprobe.d/aliases
        (You can replace the word kwrite by kate or the name of another editor)
        Change the line: alias net-pf-10 ipv6  into:
        # alias net-pf-10 ipv6
        alias net-pf-10 off
        (the ipv6 protocole should replace ipv4 but it is not still the case. Some ISP are not compatible with ipv6)
        Save and close. Then start firefox and type in the location bar: about:config
        Find: network.dns.disableIPv6  and change it from false to true
        Find: network.http.pipelining    from false to true, as well
        (Pipelining speeds up the web, but some servers are not compatible with it)
        Verify that:  network.http.pipelining.maxrequests   is 4
        Righ-click on any line and choose New/Boolean. Type: browser.turbo.enabled and set it to true
        Close and restart firefox. It should be faster now....
