Help Recovering files from Wubi install with LiveCD
    Hello. I use the commands listed at http://neosmart.net/forums/showthread.php?t=5004
    sudo fdisk -l
    sudo mkdir /win
    sudo mount /dev/sdxy /win
    sudo mkdir /vdisk
    sudo mount -o loop /win/ubuntu/disks/root.disk /vdisk
    when i type the last command, (sudo mount -o loop /win/ubuntu/disks/root.disk /vdisk) i get the following response:
    mount: you must specify the filesystem type
    what am i doing wrong?
    Intel(R) Core(TM)2 Duo CPU T5750 @ 2.00GHz<br />Mobile PM965/GM965/GL960 Memory Controller Hub
    Re: Help Recovering files from Wubi install with LiveCD
    did you acualy type
    becos /dev/sdxy is nothing............. you were suposed to replace the /sdxy part with the locatin of your windows partition as showin by the
    sudo fdisk -l
    comand......
    past the output of that comand hear.
      i replaced the xy, in actual fact i typed in:
      sudo mount /dev/hda1 /win
