I want to install lignumCAD (hosted on sourceforge) onto my 64bit machine. The source code is available, but how do I make a 64bit binary from the source? The rpm available is only for 32bit. I assume I need to compile the binary, but is there anything else I need to be concerned about? If it is that easy, how do I take it one step further and make that binary a deb package for KPackageKit to install properly in my system?
Thanks in advance,
Jimbo
Thanks in advance,
Jimbo
