wireless connection
    wireless connection
    Just installed my kubuntu and so far it seem ok. Im new to linux so I need some help.. My wireless wusb300n is recognized when I typed in the command lsusb.. But when i go to configure my network the wireless tab is greyed out. So my questions is how to I get it so I can configure my wireless adapter thanks..
    Re: wireless connection
    Assuming you installed Jaunty (you didn't tell us), then this might help you:
    Kubuntu 9.04 WiFi Problem Solved
      Yes I am using Januty. I did what was mentioned in the link with no luck.. The wireless tab is still greyed out so I can't do anything thanks..
        A search within KFN on wusb300n found three hits. While it doesn't provide instructions, this post does state that it works (for the poster) with ndiswrapper.
