I think this was bound to happen, the ubuntu success is fenominal and the seperation of the forum is normally called growth progress! It seems as if a lot of the ubuntu supporters are a bit aprehensive about this, but reading between the lines they may be mostly Gnome diehards and I am of the belief that KDE will be the GUI of choice in the foreseeable future! Anyway good luck ahead, as this is still part of Ubuntu even if seperate.
Can you let us know the plans for hosting or storing documentation, such as existing howto's, wiki's etc. These are the things mostly sought by the users and it will otherwise take quite a while before the forum has a significant amount of posts with good information. It would be a bad idea to duplicate the same documentation and it would not be a good idea to depend on new posts, so some sort of linking needs to be done. This will eventually make or break this forum.
Personally I learnt some things the hard way, there is quite a difference between ubuntu and kubuntu and then again between an ubuntu or a kubuntu only, installation or a shared kubuntu/ubuntu installation. So if some guide for kubuntu works it may be for a shared installation and does not work on a clean kubuntu only or ubuntu. The menus become a mess but some Gnome programs run very successfuly in a shared installation.
What I am saying is that any guides should say if it is for a kubuntu only or a shared installation as many at present refer to "ubuntu" even if meant for kubuntu only. Most of the guides provided by the 'geeks" are for Gnome (although they do not always state this) as they are not such great KDE users themselves it seems.
Good luck forward
Matchless
Good luck forward
Matchless
