Can't mount iPhone in Kubuntu Jaunty
    Greetings.
    I'm trying for a very long time to get help with this without success (tried IRC, ubuntuforums, you name it):
    When I was using Ubuntu 8.10 I used to be able to mount my iPhone and access it with Amarok via the convenience package and the whole ssh workaround.
    This is not working anymore, now that I've started using Kubuntu 9.04 (BTW, it's a fresh install, *not* an upgrade): when I issue the sudo iphone-mount command I get the error that my user is not in the fuse group, but the weird thing is that it *is*.
    I already checked the groups, logged out and back in and I keep receiving the same error message.
    Can anyone please help?
    TIA,
    Galvao
    Re: Can't mount iPhone in Kubuntu Jaunty
    sudo:iphone-mount comand not found... Are you sure it works properly? Have you tried "kdesudo iphone-mount"?
    <br />Have YOU signed the Ubuntu code of Conduct? I did it at 10 AUG, 2009!
      Hi, thanks for the quick reply.
      This command (iphone-mount) becomes available once you install the "ipod-convenience" package.
        You have not answered to a second question
          Right, sorry...
          When I run kdesudo iphone-mount for the first time, KDE asks me for the password and then just closes (nothing happens)...
            Right, sorry...
            oh okay. Sorry for wasting your time then because i don't know.
              Hey, no worries, at least you've tried
              I'll keep waiting, I have the impression that the cause should be something really dumb...
