[solved] karmic audio trouble
    Interesting problem with audio on karmic. This is a 64-bit system I migrated from 64-bit JJ.
    I have both alsa and pulseaudio set up, and both are listed in SystemSettings>Multimedia.
    Neither works. If I try to test alsa, I get a message saying "alsa does not work, falling back to pulseaudio". If I try pulseaudio, nothing happens. The volume indicator in the volumecontrol>playback panel moves, but in the Volume Meter (playback) panel, it does not. None of the applications like Amarok or alsaplayer produce any audio.
    There is apparently no asoundconf command; if I type asoundconf, it says I need to install alsa-utils, but that is already installed, and reinstalling doesn't fix.
    Here's the kicker: the login and logout sounds work!
    Are we going to get a karmic forum any time soon?
    Re: karmic audio trouble
    Start alsamixer and make sure that all of your audio sources aren't muted. I ran into that with one of my systems after upgrading to the previous version.
    Specs:  Intel Core 2 Quad Q6600 (@3Ghz), G.SKILL 4GB DDR2 1066, ASUS Striker II Formula MB, Asus EN9800GTX+ Dark Knight, ABS Tagan BZ800 PS, Antec 900 Case.
      Thanks for the tip. That's one of the first things I tried.
      Nonetheless, after today's updates, it's working now.
      Someone is watching... (thanks)
        Re: [solved] karmic audio trouble
        Are you talking about the output device?
        My devices are a INTEL(ICH6) and Pulse Audio.
        As backend i'm using Xine!
        I can't understand why you've got alsa in the first place
        Distributor ID: Ubuntu
        Description: Ubuntu Trusty Tahr (development branch)
        Release: 14.04
        Codename: trusty
          I admit I am no expert on alsa, but:
          ALSA stands for Advanced Linux Sound Architecture. It is a suite of hardware drivers, libraries and utilities which provide audio and MIDI functionality for the Linux operating system.
          from: http://www.alsa-project.org/main/index.php/Main_Page
          As I understand it, ALSA is basically an i/o manager and driver system, not a device per say.
          It provides the interface between the kernel and your sound card.
          A "device" in the unix world (and I am extrapolating to linux) is basically a table that points to a driver, that in turn invokes a series of modules to communicate between the kernel and a piece of hardware. Bottom line, without ALSA or some other manager/driver system, you don't talk to your sound card at all.
          Hover your mouse over the "devices" listed in SystemSettings>Multimedia, and it will list the sound system each device is using.
