Re: Quicken 2008 using Wine - installed and working
Depending on what your needs are, I have a ppa archive for the Kmymoney2 home financial program. https://edge.launchpad.net/~claydoh/+archive/ppa
My versions are from the latest codebase, and have ofx direct-download capabilities built-in (unlike the standard Ubuntu/Debian packages)
Might be worth checking out
I'm using quicken 2002 with Wine - works fine here (although I've not done online banking with it and I don't get the cash register sound!).
I've been questioning for some time now whether to move to either Gnucash or KMymoney. I have several accounts of different types and standing orders. Any views on which would be better for the job? I have to add that a couple of months ago I did try to import a QIF file into Kmymoney and it didn't seem to work too well.
Hi All,
I've tried several vesions of KMyMoney (including Claydoh's ppa). On all of them the Help files are unavailable. The message says khelpcenter is not there; but it is. Is this a problem with KDE4.2 as I notice that KMyMoney is built for kde3.5.
this is wonderful news hopefully quickbooks will work w/ wine soon too.it aparently requires IE6 and don't reconize ie4linux as satisifying the requirement , no luck w/ the wine-gekko package either... or even better if ne one know a way for me to copy my company data to a format that i could use w/ kmymoney / lemon pos (we use qbpos too, so i think were stuck with it for the time being.)
Mark Your Solved Issues [SOLVED] (top of thread: thread tools)
If my Google research is right, Quickbooks uses IIF format whilst Quicken uses QIF. Nice stitch up! I have seen loads of converters from QIF to IIF but none the other way around. What format(s) can quickbooks export in?
I suspect none. However if it can export to QIF then as I assume you're talking about a full-blown set of corporate accounts rather than home banking then I think you should be looking at gnucash, although if you can't export to some format other than IIF then I think you might be in for fun and games.
I suppose that's the whole point of having no export options - you have to do it all manually which makes it a very, very, big job so the incentive is not to move.
I'll keep my ear to the ground and if I hear anything of use to you I'll let you know.
