OK the meaning of this post is to help me and others with similar problems to get off the dual boot and move to VM instead.
I'll post my experience and links about this here. Hope that this will help anyone (well at least me..)
I found a old thread on this forum that explained how you can convert your physical XP "machine" in virtual using VMware converter.
But I cant find VMplayer in add/remove or Adept / Synaptic.
So I went to VMware site to download it, but there is o .deb file, there is .rpm a "sourcecode" in tar.gz and .bundle.
I guess I should try .rpm with alien? Is that correct...
Anyway I know about virtualbox and would like to use it instead of VMplayer, I did found how to change physical machine in virtual, but it's not that
straight forward as the VMware. And it's said that you can loos all of your data in trying this (which I don't want to..).
Anyway what I want to know:
Does anyone know what happened to VMplayer, why is there none for Kubuntu?
Is it safe to even have VM on 32 bit one core processor.
What are your experience with virtualbox and/or VMplayer.
Are they even useful as an "gaming platform", that's why I want to use the VM windows.
Thanks for all the help, suggestions or experience...
PS: how to virtualise existing Windows with:
Virtualbox: http://forums.virtualbox.org/viewtopic.php?t=1966
VMware: http://www.howtoforge.com/vmware_con..._windows_linux
