Just installed Dapper 6.06 Amd64 by mistake. How can I help?
    Hi
    I have just installed kubuntu and find I have a Dapper 6.06 beta version (my fault). I have been using FreeBSD and found the time taken by portsnap silly.
    I have found a few problems but most of these can be worked around apart from saving in Open Office when the computer hangs.
    I am running kubuntu on a 80Gig hard drive with Windoze Me on a seperate 20Gig (i need this for  a course I am doing) If you would like me to try/run/report anything as long as you tell me what you would like me to do and how to report it I would be happy to do so.
    I am running an Asrock  939A8X-M motherboard with a AMD Athlon 3200 CPU and a GeForce 4 MX 440-8X graphics card and 1gig of RAM with a Dell E173FP monitor.
    Re: Just installed Dapper 6.06 Amd64 by mistake. How can I help?
    Welcome to Kubuntu! If you want to help out, take a look at this Wiki page: https://wiki.kubuntu.org/KubuntuDapperBetaFeedback and, more generally: https://wiki.kubuntu.org/HelpingKubuntu
