I have Ubuntu 7.10 installed on my laptop and after playing with my friends version of Kubutnu 8.04 I liked it better than regular Ubuntu. How would I go about switching from Ubutntu to Kubuntu? -Thanks.
Switching to Kubuntu
Re: Switching to Kubuntu
Kubuntu FAQ:
I already have Ubuntu installed, how can I get Kubuntu?
1. Install kubuntu-desktop either with Synaptic or the command line apt-get install.
See InstallingKDE for a full explanation.
> InstallingKDEBefore you edit, BACKUP !
Why there are dead links ?
2. Thread: Lost Information
Of course, if you follow the procedure presented in the previous post, YOU WILL LOSE ALL YOUR PERSONAL STUFF. So either, backup all your personal stuff (not quite as easy as it sounds, but check some of the threads in the How-To section of this site) or:
(0) Backup, anyway, just in case.
(1) Install kubuntu-desktop (as suggested above).
(2) Remove ubuntu-desktop.
(3) Upgrade to Hardy
or (if you have room)
(2a)Don't remove ubuntu-desktop and have the best of both worlds.
