Hi there, I switched over to kubuntu HH yesterday. So far I'm liking it, with the exception of one thing: It's unusable unless I start in failsafe mode, then start kicker and kwin manually from command line.
By "unusable" I mean that every widget on every window takes about 10 minutes to draw, and when I looked in ksysguard I found that the programs I'd started had started around 20 times each, and seemed to be continually spawning copies of themselves.
Is this I known issue? If so, or if not, can anyone help me diagnose and fix this?
Thanks for your help.
and these are effects you can have.
