sun java 6 for firefox
    when I run the install for sun java6 for firefox through terminal,this is what I get,and what does it mean?
    E: Package sun-java6-plugin has no installation candidate
    and how do I install sun java6 for firefox?
    Re: sun java 6 for firefox
    Make sure you have the multiverse repository enabled.
      that repository is open what do I do now?
        You should now be able to install it with:
        sudo apt-get install sun-java6-plugin
          this is what i get when i attempt to run the install using terminal..
          Reading package lists... Done
          Building dependency tree
          Package sun-java6-plugin is not available, but is referred to by another package.
          This may mean that the package is missing, has been obsoleted, or
          is only available from another source
          why is that? i would love to start using firefox..or should i wait till FF3 is released?
            I'm not sure what is happening there. Did you run
            sudo apt-get update
            after enabling the multiverse repository?
              i ran the sudo command in the terminal.....i still don't see anything about a sun java6 plugin
                Can you post the output of
                 cat /etc/apt/sources.list
                  I just found java 1.4 which is a plugin for mozilla/firefox
                    here is the output of a post by someone earlier
                    deb cdrom:[Kubuntu 7.10 _Gutsy Gibbon_ - Release amd64 (20071016.1)]/ gutsy main restricted
                    # See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
                    # newer versions of the distribution.
                    deb http://us.archive.ubuntu.com/ubuntu/ gutsy main restricted
                    ## Major bug fix updates produced after the final release of the
                    ## distribution.
                    deb http://us.archive.ubuntu.com/ubuntu/ gutsy-updates main restricted
                    ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
                    ## team, and may not be under a free licence. Please satisfy yourself as to
                    ## your rights to use the software. Also, please note that software in
                    ## universe WILL NOT receive any review or updates from the Ubuntu security
                    ## team.
                    deb http://us.archive.ubuntu.com/ubuntu/ gutsy universe
                    deb http://us.archive.ubuntu.com/ubuntu/ gutsy-updates universe
                    ## multiverse WILL NOT receive any review or updates from the Ubuntu
                    ## security team.
                    deb http://us.archive.ubuntu.com/ubuntu/ gutsy multiverse
                    deb http://us.archive.ubuntu.com/ubuntu/ gutsy-updates multiverse
                    ## Uncomment the following two lines to add software from the 'backports'
                    ## repository.
                    ## N.B. software from this repository may not have been tested as
                    ## extensively as that contained in the main release, although it includes
                    ## newer versions of some applications which may provide useful features.
                    ## Also, please note that software in backports WILL NOT receive any review
                    ## or updates from the Ubuntu security team.
                    # deb http://us.archive.ubuntu.com/ubuntu/ gutsy-backports main restricted universe multiverse
                    # deb-src http://us.archive.ubuntu.com/ubuntu/ gutsy-backports main restricted universe multiverse
                    ## Uncomment the following two lines to add software from Canonical's
                    ## 'partner' repository. This software is not part of Ubuntu, but is
                    ## offered by Canonical and the respective vendors as a service to Ubuntu
                    ## users.
                    deb http://archive.canonical.com/ubuntu gutsy partner
                    # deb-src http://archive.canonical.com/ubuntu gutsy partner
                    deb http://security.ubuntu.com/ubuntu gutsy-security main restricted
                    deb http://security.ubuntu.com/ubuntu gutsy-security universe
                    deb http://us.archive.ubuntu.com/ubuntu/ gutsy-proposed restricted main multiverse universe
                    deb http://security.ubuntu.com/ubuntu gutsy-security multiverse
                      I wish you had stated in your opening post that you were running the 64 bit version.
                        In my Hardy Heron Adept Manager which has all relevant repositories enabled, I see no such package as "sun-java6-plugin". So it may well not be available for 64-bit. If this is a serious problem, there are ways to install the 32-bit version of Firefox on a 64-bit Linux installation. I haven't personally needed to do that -- I would suggest checking the 64-bit forum at Ubuntu Forum for detailed instructions.
