OK. I was asked about the default Screen Resolution for VirtualBox being "stuck" @ 800x600. I erroneously stated that it appeared that it can't be changed or at least I've never found anything stating to the contrary. Well, with a little more digging, I found that Innotek does supply this file "/usr/share/virtualbox/VBoxGuestAdditions.iso". It is to be used inside the virtual machince while running mounted as a CDROM thought the VirtualBox Disk Management system. Using this and following the directions in their Help File(CH. 4 /Section 4 - whatever they designated as) should allow one to change the screen resolution higher. I'm not at my test machine to further test this, but I believe this will get it.
Actually I can't wait.
Testing KDE4 at 800x600 has been a real downer.
![Grin](https://www.kubuntuforums.net/core/images/smilies/grin.gif)
