how to block the upgrade of a package
    Hi all, I'm running a brand new Hardy Heron box.
    I would like to know how can I do in order to DO NOT UPGRADE a package to the proposed one.
    I don't wont to install firefox 3.0 and keep the 2.X series.
    thanks to all
    Leo
    Re: how to block the upgrade of a package
    The easiest way is to uncheck that package in adept or in my case synaptic before upgrading.
    4 GB Ram
    Kubuntu 18.10
      You could pin version:
      Pinning version
      http://kubuntuforums.net/forums/inde...9271#msg109271
      You could also downgrade packages (if you already installed unwanted version)
      How to downgrade packages (forcing version)
      http://kubuntuforums.net/forums/inde...opic=3090553.0
      Before you edit, BACKUP !
      Why there are dead links ?
      2. Thread: Lost Information
