Can someone please advise me step by step how to add the repositories from dvds. I bought the 7 dvd set of Kubuntu 7.10 and can find instructions for installing from the net, but none that cover installing from cds or dvds.
I would appreciate any help I can get on this one.
If you'd rather use your CD-ROM for installing packages or updating your system automatically with APT, you can put it in your sources.list. To do so, you can use the apt-cdrom program like this:
# apt-cdrom add
with the Debian CD-ROM in the drive. It will mount the CD-ROM, and if it's a valid Debian CD it will look for package information on the disk. If your CD-ROM configuration is a little unusual, you can also use the following options:
-h - program help
-d directory - CD-ROM mount point
-r - Rename a recognized CD-ROM
-m - No mounting
-f - Fast mode, don't check package files
-a - Thorough scan mode
For example:
# apt-cdrom -d /home/kov/mycdrom add
You can also identify a CD-ROM, without adding it to your list:
# apt-cdrom ident
Note that this program only works if your CD-ROM is properly configured in your system's /etc/fstab.
